JohnWR Posted March 4, 2017 Share Posted March 4, 2017 Hi i am doing the engine on my legacy and i finally got to the step to install my heads, I am using ARP head studs and after installing them and torquing the heads i am having serious regrets about my choice. Sorry for the long read i'm just scared to screw this up as no one at my dealership has ever used studs before. 1st problem is i received my first kit back in july of 2016 when i started gathering parts for my rebuild. I opened and inspected the studs and never thought to check the nuts, My kit had nuts with no threads cut in them. I found this out after trying to install my first head today so that resulted in a trip to EFI logics to buy another set. My second problem is while doing my torquing of the nuts after using the supplied lubricant on block threads and nut threads and installing hand tight with an allen wrench. I had to torque them and loosen them at least once and double check the studs as during the initial torque. One nut would fall flat like the stud twisted further into the block but loosening all nuts and making sure the studs were tight i could get 30,60,90 on the second attempt no problem. Is this normal or did i just screw up my head gaskets? Thanks everyone for any help and sorry for the long post. Link to comment Share on other sites More sharing options...
JohnWR Posted March 4, 2017 Author Share Posted March 4, 2017 Sorry forgot to say this is a brand new subaru block as well not a used one so the thread holes were clean and virgin. Link to comment Share on other sites More sharing options...
Darth SpecB Posted March 4, 2017 Share Posted March 4, 2017 It should be fine since tightening the nuts will pull the studs away from the block not push them in further. Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted March 7, 2017 Share Posted March 7, 2017 I have to agree ^. you should be fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JohnWR Posted March 8, 2017 Author Share Posted March 8, 2017 I'll update this first when calling ARP a person always answer the phone never a machine this is a very nice touch. I was dealer with a supervisor and he said we would refund me the most expensive set of head studs when i returned them for the missing threads in the nuts that's great for me and my wallet. Second for having the torquing issue he had me pull my heads back off and inspect for grease under the washer as they are not supposed to have grease there as it can allow the washer to rotate and cause reading issues. This was my cause i changed my head gaskets just to be safe made sure the washer and head were clean and i had no issues getting he heads to torque to spec this time. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 10, 2017 Share Posted March 10, 2017 Good to hear, I would not build a boosted motor without using ARP head studs. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted March 11, 2017 Share Posted March 11, 2017 good to hear, i would not build a boosted motor without using arp head studs. this 100% 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
