vinson Posted March 2, 2017 Share Posted March 2, 2017 Hey everyone, So i recently have had a problem with my legacy it has 298000km and has stopped shifting into any gears where as a few days ago it shifted fine. what i have noticed is that the pedal seems to be alot lighter theres no resistance doesnt feel like im putting out any pressure really. secondly the car does start but even when i put immense pressure on the clutch pedal i still cant go into gears. i find once that it does warm up i can go into gears but the shifter has to be pulled fairly hard almost like shifting a semis shifter. I dont know if whether has anything to do with this but i do live in canada and our current temp is around - 9 degrees. have any suggestions ? Thanks much appreciated !! Link to comment Share on other sites More sharing options...
RustyRuu Posted March 2, 2017 Share Posted March 2, 2017 hows the fluid in the clutch master cylinder? is it low or ok level. how does the clutch fork and slave look, any wiggling or noise coming from them? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 8, 2017 Share Posted March 8, 2017 FWIW, old tranny's in the 1st gen legacy's had an issue where they would get stuck between gears. I thinking the tranny may need to come out... I guess you have checked the fluid level in the clutch cylinder ? -9F should not have any effect, unless theirs water in the fluids. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
