JackLGT Posted February 28, 2017 Share Posted February 28, 2017 Okay so I have experienced this before, but my engine light keeps coming on, trac off light, and the cruise control is blinking. This will not stay off. Now that I got an access port, I keep clearing the codes and it'll appear like 10 miles later. I know that this usually is because the gas cap is loose but I know it's definitely on tight. I noticed that the little door for gas or whatever you wanna call it wasn't on enough, so maybe that's it, but if you have any ideas of what else it could be please let me know! (You can't see the cruise blinking in the pic) Link to comment Share on other sites More sharing options...
Max Capacity Posted February 28, 2017 Share Posted February 28, 2017 You might have a bad wheel speed sensor. You'll need to use the AP to read the CEL code. CC will not work if you have a CEL http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hirschman Posted February 28, 2017 Share Posted February 28, 2017 Yeah, what Max said. Have you tired using the AP to read what the code is for? Betting it is not the gas cap, could be hundreds of things. Read the code, report back and we'll be able to better help. Link to comment Share on other sites More sharing options...
