ktm200 Posted February 23, 2017 Share Posted February 23, 2017 Was really hoping someone could help or has seen this problem. About a month ago, while tracking down what turned out to be a bad exhaust valve, I threw a P2092 code that kept popping up "OCV open circuit bank 2". So I tried pulling the OCV to clean it with some power lube. Moved freely but it still threw the code. So I swapped drivers and passenger side OCVs and the problem went away. A few days later I tore the motor down to have the heads rebuilt. So this weekend I get it back together. Runs fine for two days and this morning I threw a P2088 code. Same code as before but only bank 1 now (turbo side). So tonight I pulled both again and cleaned them both and swapped which side I put them back in. Immediately get P2092 which means the code followed the OCV. So I initially thought just get a new OCV. However here is where I'm confused. When the code was on the passenger (turbo) side, if I monitored both left and right OCV duty % they both went from around 9% at idle and stayed around 47-50% while cruising on the highway. However once I swapped the valves to the opposite sides (code on the drivers side bank) BOTH OCV duty % never leave 9% regardless of throttle input and load. So not knowing enough about the OCV system, what could be cause this? I just assumed that if one valve was bad, that one would have % errors and the other valve would be fine. Are they somehow tied to each other?? After having the car down a month for a turbo and head rebuild it is driving me absolutely nuts to have ANOTHER damn code thrown. Would appreciate any input. Just want to have a better idea before I blindly throw even more money at the car. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 25, 2017 Share Posted February 25, 2017 In the back of the service manual there is a section for how things work, http://people.csail.mit.edu/ilh/vacation/ May be that will help... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
