balbrec2 Posted February 15, 2017 Share Posted February 15, 2017 So here is something I haven't found a thread on but would like some info if anyone has the knowledge. When your CEL comes on I know that the cruise control and vehicle stability control are disabled. Is there anyway any of these could cause the CVT to act more abruptly. Instead of the normal vague shift points that I am used to, there is now a more abrupt shift at around 30 mph. Otherwise all seems normal except for the warning lights. No noises or performance issues. I don't have any codes at this time but have an appt for the dealer in a few days, still under warranty. Thoughts please. Thanks in advance. Link to comment Share on other sites More sharing options...
spect2k Posted February 15, 2017 Share Posted February 15, 2017 You have a CEL without any codes? Is that what you're saying? Link to comment Share on other sites More sharing options...
balbrec2 Posted February 16, 2017 Author Share Posted February 16, 2017 No. What I'm saying is I haven't had the ECM checked yet for a code that is causing the CEL to come on. Link to comment Share on other sites More sharing options...
spect2k Posted February 16, 2017 Share Posted February 16, 2017 Got it. Without knowing what's going on, there is certainly a chance you could be having driveability issues. If the abrupt shifting has coincided with the CEL, I would say it is likely they are connected. A CEL, regardless of the issue, changes the way the car functions. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 16, 2017 Share Posted February 16, 2017 Yeah hook a scanner up to it if the MIL (aka Money Indicator Light) is lit then you should be able to retrieve the code. Link to comment Share on other sites More sharing options...
balbrec2 Posted February 22, 2017 Author Share Posted February 22, 2017 Dealer says it is a bad intake manifold sensor. Had to order part. Still under warranty so cost should be nil. Link to comment Share on other sites More sharing options...
surmiser Posted February 23, 2017 Share Posted February 23, 2017 Dealer says it is a bad intake manifold sensor. Had to order part. Still under warranty so cost should be nil. As in bad mass airflow (MAF) sensor? @redvenetian on Instagram Link to comment Share on other sites More sharing options...
