imrbilly Posted February 15, 2017 Share Posted February 15, 2017 Hello All, New member here. Please be kind 2017 Legacy 3.6R. I got a flat tire over the weekend and when I went to change the tire I got every check light ON!. I eventually restarted the car and everything went away EXCEPT the check engine light. I drove it around and it stayed. So I naturally made an service appointment with the closest service center for the following day. That morning I started the car and the check engine light was gone. I went to the service center anyway and they said that there is nothing they can do since there is no light. Isnt there any diagnostic they can do? Recommendations? Thanks. Billy. Link to comment Share on other sites More sharing options...
MrCobbs Posted February 15, 2017 Share Posted February 15, 2017 Hey there and welcome to the forums. It's unfortunate that they did not at least attempt to pull codes. Just go to a different dealership to see if they can pull codes or run a diagnostic and don't take no for an answer. I've heard people mention that it's something with the gas cap or something on a new car. Link to comment Share on other sites More sharing options...
SubiFTW Posted February 15, 2017 Share Posted February 15, 2017 I had my CEL come on with only a few hundred miles on the vehicle.. got serviced at the dealership and they said that my gas cap wasn't on tight. Which didn't make sense to me because I remember pulling my gas lever and tightening my gas cap.. but the CEL was still on after that. Who knows what happened, but the CEL hasn't been on since. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
chowser51 Posted February 15, 2017 Share Posted February 15, 2017 Get a code scanner so you can diagnose yourself before you go to the dealer. Yes. I know it's a new car but everyone should be able to read their own codes so unscrupulous service people can't scam you. Link to comment Share on other sites More sharing options...
The Grey Goose Posted February 15, 2017 Share Posted February 15, 2017 A cheaper alternative is to buy a bluetooth OBDII reader and get an app that can read codes. Costs about $15 Link to comment Share on other sites More sharing options...
ammcinnis Posted February 15, 2017 Share Posted February 15, 2017 ... they said that my gas cap wasn't on tight. Which didn't make sense to me because I remember pulling my gas lever and tightening my gas cap.. but the CEL was still on after that. In case of a loose fuel cap, the CEL will remain lit for some time (i.e. several start cycles) after the cap is properly tightened. Also, in most cases a diagnostic trouble code will be stored in the on-board computer(s), and can be retrieved, even after the CEL is canceled. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
upstater Posted February 15, 2017 Share Posted February 15, 2017 probably something related to the TPMS system, aka tire pressure. Not every check engine light is due to a gas cap. That said, if they checked it and cleared the code, or the code disappeared, nothing you can do about it now. If you get a code reader, you can see what is wrong before the code goes away, or the dealer clears it. Link to comment Share on other sites More sharing options...
slk5060 Posted February 16, 2017 Share Posted February 16, 2017 probably something related to the TPMS system, aka tire pressure. Not every check engine light is due to a gas cap. That said, if they checked it and cleared the code, or the code disappeared, nothing you can do about it now. If you get a code reader, you can see what is wrong before the code goes away, or the dealer clears it. TPMS is its own light Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
