relative4 Posted February 11, 2017 Share Posted February 11, 2017 When playing after a recent snowstorm, I let off the throttle when I should have added gas, swung the rear end too far, and tapped my rear wheel on a curb. The bearing is shot, verified while I had it off the ground for a sway bar upgrade this week. So many brands of bearing/hub assemblies out there. Any brands particularly good or bad these days? Link to comment Share on other sites More sharing options...
apexi Posted February 11, 2017 Share Posted February 11, 2017 I installed 2 timkens in the rear over the summer, no complaints about them at all. Removing the old bearings with 195k is a different story though.. Ended up going out to buy an air hammer in the middle of the job, which made removal a piece of cake. Link to comment Share on other sites More sharing options...
relative4 Posted February 11, 2017 Author Share Posted February 11, 2017 Thanks for the heads up on the air hammer, last hub I did just about destroyed my shoulder. How do you use the air hammer for this job? Having trouble envisioning how to get it to cooperate with a slide hammer. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 11, 2017 I Donated Too Share Posted February 11, 2017 I use an inexpensive air chisel... put it on the side of the old bearing and brrrrrrrrrrapppp - shakes it loose and lets you get behind it. I have struggled with many bearing changes without this and using the tool is night and day and saves hours of frsutration. Can sometimes mess up the backing disk a little but I just bang that edge flat with a hammer on the ground and all is okay. Link to comment Share on other sites More sharing options...
apexi Posted February 11, 2017 Share Posted February 11, 2017 In the picture above, second from top, you have the pointy attachment. My axles were stuck in the hubs, and on the ends of the axles there's a little indentation that you can press the pointy tip into, and use the air hammer to push them out of the old hubs. Link to comment Share on other sites More sharing options...
CapnJack Posted February 11, 2017 Share Posted February 11, 2017 So many brands of bearing/hub assemblies out there. Any brands particularly good or bad these days? http://legacygt.com/forums/showthread.php/success-non-oem-wheel-hub-bearing-units-221269.html Link to comment Share on other sites More sharing options...
relative4 Posted February 26, 2017 Author Share Posted February 26, 2017 I am seriously stoked. With apexi's help, I just learned the RIGHT way to pull a hub. I was pulling a rear hub. After removing the 4 hub mounting bolts, I inserted an old set of front hub mounting bolts I had lying around. The difference is, the front bolts are longer. To use this technique on a front hub, I'd recommend finding some even longer bolts. Then I tapped the bolt heads with the air hammer. Turns out I only needed 2 bolts. Brap, brap, and the hub was out. Seriously, it took less time than it's taking me to type this sentence. Man, do I feel dumb for the half hour I spent trashing my shoulder the last time I pulled a hub with a slide hammer. Link to comment Share on other sites More sharing options...
