AndrewF Posted February 3, 2017 Share Posted February 3, 2017 This might be a dumb question, but I am fairly new to the legacy crowd. Has anyone on here done an EJ207 or EJ257 swap to their fourth gen? If yes, is it worth doing? Link to comment Share on other sites More sharing options...
MilesA Posted February 3, 2017 Share Posted February 3, 2017 Does it make sense? It might make more sense to upgrade the engine we already have. That is much more common. https://www.google.com/search?q=ej257+ej255+swap+site%3Alegacygt.com Link to comment Share on other sites More sharing options...
Max Capacity Posted February 3, 2017 Share Posted February 3, 2017 Yep most of us use a ej257 short block and our heads. See my click here link. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted February 3, 2017 Share Posted February 3, 2017 If you have a 2005 or 2006 Legacy GT, you already have an STI shortblock from the factory, AFAIK. You only need a new shortblock if the original one is shot. A lot of people have not had to do a shortblock/rebuild yet. Link to comment Share on other sites More sharing options...
Smithcraft Posted February 4, 2017 Share Posted February 4, 2017 From what I've read, many people consider the EJ20x to be a bit underpowered for Legacys. Yet they are the standard engine for the Legacy around the world. SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
AndrewF Posted February 4, 2017 Author Share Posted February 4, 2017 Does it make sense? It might make more sense to upgrade the engine we already have. That is much more common. https://www.google.com/search?q=ej257+ej255+swap+site%3Alegacygt.com I have an 09 with just the 2.5i, but I didn't know if it be easier to try and upgrade it while also being durable enough to last, or to just start fresh. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2017 Share Posted February 4, 2017 The general rule is if you want a GT, buy one, it's not cost effective to try and build your own from a 2.5i. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted February 5, 2017 Share Posted February 5, 2017 Just about anything is possible with enough money. But there are many downsides. It costs more than you think it will. It takes longer than you think it will. You have to deal with electrical and wiring. Custom tuning on an uncommon configuration. You have to comply with emissions and inspection laws in a lot of places. And having an oddball engine could be a PITA if you needs parts or service in the middle of a long trip. Or just to get to work the next day. Not trying to ruin your fun, but I agree with Max that a GT would be a better starting point with a lot less hassle overall. Link to comment Share on other sites More sharing options...
AndrewF Posted February 8, 2017 Author Share Posted February 8, 2017 The general rule is if you want a GT, buy one, it's not cost effective to try and build your own from a 2.5i. So Im looking at trading mine in for an 06 LGT limited with 133k. They want $6,999 for it, it has new head gaskets, timing belt, and water pump. Is that a relatively fair price? im not sure what the GT's go for compared to the regular legacy's. Link to comment Share on other sites More sharing options...
Dishwasher Posted February 8, 2017 Share Posted February 8, 2017 If compression and leakdown numbers are good, and the turbo has no shaft play then that sounds like a solid car. If you're not mechanically inclined, you will want to have a reputable mechanic look it over on top of those items. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
