kent55 Posted January 24, 2017 Share Posted January 24, 2017 I moved this to the 4th Gen 05-09 Legacy section installing-hids-need-help-wires Hi. I'm installing H7 HIDs in my low beams and can't figure out the best way to connect the bulb wire to the ballast. Do I need to drill a hole through the waterproof cover? Also I was planning to use an upgraded wiring harness that connects to the battery that would require the female end of the headlight plug to be on the outside of the housing. Do I need to splice into the harness before that wire goes through the headlight housing.... Or can I buy the harness adapter and make my own harness with out affecting the original? Lastly, how do I remove the headlight housings if needed? Does the bumper need to come off? Link to comment Share on other sites More sharing options...
kent55 Posted January 24, 2017 Author Share Posted January 24, 2017 I see a hole needs drilled (shown in this video) . Link to comment Share on other sites More sharing options...
LatentWagen Posted January 24, 2017 Share Posted January 24, 2017 No need for two threads on the subject, when you're getting responses in the other thread: http://legacygt.com/forums/showthread.php/installing-hids-need-help-wires-housing-259473.html?t=259473 Also, no need for HIDs LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
