Tschagfreebird151 Posted January 20, 2017 Share Posted January 20, 2017 So does anyone else have a slow battery drain, on their 06 B? Whenever I have to park my car longer than a week, I will have to jump start it. I do not have an aftermarket stereo, my interior has been left stock, I welcome all ideas. I took it to Chaplin's in Bellevue twice... they could not find anything wrong both times..... Thank you. Link to comment Share on other sites More sharing options...
MilesA Posted January 20, 2017 Share Posted January 20, 2017 This kind of problem can be tedious to diagnose, but one way of doing it is with a multimeter or circuit tester. With ignition switch off, you would test each fused circuit at the fuse box to measure current flowing. There should normally be zero current. Maybe a few milliamps for alarm, clock and keeping radio stations in memory. Here is a how-to article showing the process: http://www.popularmechanics.com/cars/how-to/a5859/how-to-stop-car-battery-drains/ Link to comment Share on other sites More sharing options...
MilesA Posted January 20, 2017 Share Posted January 20, 2017 Just thought I'd mention two common causes of this issue (on many cars, not just the Legacy). 1) Trunk light stays on when trunk lid is closed. 2) Car alarm draws more power than normal when ignition is off. Link to comment Share on other sites More sharing options...
sunny5280 Posted January 20, 2017 Share Posted January 20, 2017 How old is the battery? Link to comment Share on other sites More sharing options...
outahere Posted January 21, 2017 Share Posted January 21, 2017 ..I took it to Chaplin's in Bellevue twice... they could not find anything wrong both times..... Thank you. Did they measure parasitic current? How much was it? What is the condition of the battery? Link to comment Share on other sites More sharing options...
Tschagfreebird151 Posted January 21, 2017 Author Share Posted January 21, 2017 The Battery is an interstate, 2 years old, It seems to be in nice shape, and no the dealer (Chaplins) did not do that test... I did not even think to ask, wish they would have suggested it. Thank you for the suggestions. I will keep at it, and let you know my progress. Link to comment Share on other sites More sharing options...
Tschagfreebird151 Posted January 21, 2017 Author Share Posted January 21, 2017 I have a pretty good multi meter, I will you tube a video and see if I can measure parasitic current. Link to comment Share on other sites More sharing options...
outahere Posted January 22, 2017 Share Posted January 22, 2017 Do a search for service bulletin 07-62-07 for the procedure. Max allowable current is 150mA. Link to comment Share on other sites More sharing options...
Tschagfreebird151 Posted January 23, 2017 Author Share Posted January 23, 2017 I am in the process of reading through that thread! Seems very similar to that problem. Link to comment Share on other sites More sharing options...
Tschagfreebird151 Posted January 23, 2017 Author Share Posted January 23, 2017 So one guy had to trade his in and the other guy had some issues with the backup lights, I am still trying to go through my fuse box to determine my problem. I am going to wire up my JDM Head lights hopefully this weekend, and my JDM Folding mirrors, and then during that time, I hope to discover the slow battery drain. However it is such a low pull, that I am under the impression that it will be a stroke of good luck if I ever find it. My hope is that I fix the problem as I am messing around with new wiring. Thanks for all the help. More suggestions are always helpful and welcome. Link to comment Share on other sites More sharing options...
whitrzac Posted January 24, 2017 Share Posted January 24, 2017 AP/tatrix left plugged in? Anything in the OBD2 jack? Parking light switch? Link to comment Share on other sites More sharing options...
sunny5280 Posted January 24, 2017 Share Posted January 24, 2017 So one guy had to trade his in and the other guy had some issues with the backup lights, I am still trying to go through my fuse box to determine my problem. I am going to wire up my JDM Head lights hopefully this weekend, and my JDM Folding mirrors, and then during that time, I hope to discover the slow battery drain. However it is such a low pull, that I am under the impression that it will be a stroke of good luck if I ever find it. My hope is that I fix the problem as I am messing around with new wiring. Thanks for all the help. More suggestions are always helpful and welcome. I would suggest holding off on any electrical modifications until you've resolved this issue. Link to comment Share on other sites More sharing options...
grovlet Posted January 24, 2017 Share Posted January 24, 2017 I would suggest holding off on any electrical modifications until you've resolved this issue. I would also start checking all the interior bulbs - shot in the dark - but sometimes just pulling them out and putting them back in can help - also look for any corrosion on them? You can also try turn signals and brake lights for loose/corrosion? Check your battery terminals as well - are they clean or covered in white corrosive powder = clean the battery terminals? But yeah no new electronics until you solve this is a better plan..... Link to comment Share on other sites More sharing options...
