janie27526 Posted January 16, 2017 Share Posted January 16, 2017 Hi all--just getting my 05 OB XT limited and wanting to add back up camera. Has anyone had luck doing this? Willing to tinker with head unit and sound as well if I can find alway to integrate it all. Thanks in advance! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
bhavedikian Posted January 20, 2017 Share Posted January 20, 2017 I have, let me see if I can dig up the threads to assist you as they're on this site. Link to comment Share on other sites More sharing options...
bhavedikian Posted January 20, 2017 Share Posted January 20, 2017 Here you go...http://legacygt.com/forums/showthread.php/backup-camera-walk-through-4th-gen-w-nav-241555.html Link to comment Share on other sites More sharing options...
bhavedikian Posted January 20, 2017 Share Posted January 20, 2017 Oh, and this as well, sorry for not putting them on the same post: http://legacygt.com/forums/showthread.php/reverse-camera-connector-pinout-132007.html?p=2943792&postcount=21 Link to comment Share on other sites More sharing options...
bhavedikian Posted January 20, 2017 Share Posted January 20, 2017 Yep it's all ready to go once you plug in the cam etc. Svxdc iirc was selling the camera adapters... https://www.google.com.au/search?q=s....0.pM4cV5_fNdc http://forum.liberty.asn.au/viewtopi...0939&start=390 https://www.google.com.au/search?q=s....0.Bu24CzNDQbA Originally Posted by bhavedikian What exactly did you do to display your phone on the Nav screen? I have a 2008 LGT with the P-204UH unit so I was wondering if I could do it with my Note 3 phone. Originally Posted by bigBADbenny The Nav screen has an RCA video aux in located on the rear of the unit. Use a quality shielded RCA cable and route it to the center console, then hook it up to the devices video out, eg via an mhl to composite RCA etc. You'll also need to do the 2x nav hacks to use the video aux in on the move. That's grounding a pin on the DVD map drive unit, and grounding a wire leading to the nav screen harness. Originally Posted by bhavedikian Right on, thank you for the quick response. Does the RCA hookup take the place of the leads from the DVD drive so that nav and the other screen items aren't available? If not, how do you switch between the two? Does it sense when the AUX in receives a signal and auto switches to it? Originally Posted by bigBADbenny No, it's a discrete input, switching is controlled via the aux in button on the front of the Nav unit. Originally Posted by bhavedikian OK, good deal. I read after I sent the message about hitting one of the buttons twice to switch as well as a molex connector for a backup camera which I'll hook up someday if our model has it. Link to comment Share on other sites More sharing options...
bhavedikian Posted January 20, 2017 Share Posted January 20, 2017 I think that should do it. When I performed this I added three RCAs to the bottom of the arm rest as well; left, right, video. I plugged in an RCA to HDMI converter and then used an OTG adapter to plug it into my Note 3 phone but the display has very poor res and then I had to upgrade to the Note 5 which forced me to switch to using Chromecast to get the display of the phone on the navi screen. I can get the exact res of the screen but it's like 420x234 or something. I picked up a cam from Amazon that was cheap but it does the job, not sure how much it's worth getting a proper one with that low of res. Link to comment Share on other sites More sharing options...
bhavedikian Posted January 20, 2017 Share Posted January 20, 2017 I actually ran into the PDF for the nav unit on my phone so here are the specs I have on it: Kenwood FGZ000UF2 7" Transparent TN LCD panel TFT active matrix 400(h)x234(w) RGB RGB striped pixel arrangement Back lit cold cathode tube Operating voltage is 13.2v DC (10.8~15.6v) Link to comment Share on other sites More sharing options...
