5EAT Dyno
It's a spike ignore it. Notice how the curve drops like a rock? Only way to eliminate it is to "lock" the converter via a lockup switch. Not sure if it's even an option on the Subys. The hp numbers would rise a bit locked as well.
It is kind of wierd that your torque band falls so quick. I can post up my dyno if you want to compare the two. Or search for my thread under TDC.
As for dynapack; I am pretty sure that they measure horsepower which converts to torque. You can't measure both. One does the other. So like the dyno I ran on measured torque which converted to horsepower. There are other factors like correction factors and toque converters, etc.
