05gtwannabe Posted January 10, 2017 Share Posted January 10, 2017 Hi all, My sedan is giving me a prob. Non- turbo manual Looking to replace stock exhaust- after cats. I have the three cat bodies. Purchased the pipe that splits, and the two rear mufflers (from Advanced)-but it won't fit- the hanger is too far to the rear when the front is mounted up. What's weird is the pic attached-with 3 bodies-says it's for an auto-I have a stick. What parts do I actually need? Do I need to go to Subi? http://uploads.tapatalk-cdn.com/20170110/8c98861aed4726d875fb639a0ffb92e5.pnghttp://uploads.tapatalk-cdn.com/20170110/863a7bc5337ac7ddd4d17f393205d18b.png Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2017 Share Posted January 10, 2017 I would have Advance look up the system from another manufacture. You may need the build date from the inside of the drivers door jam. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
