2_From_NH Posted January 7, 2017 Share Posted January 7, 2017 Does anyone know the torque spec for the strut-hub bolts? I'm going to see if I can get a good estimate with my torque wrench, otherwise it's going to be 200 ft lbs. And while searching for that, I realized how awesome it would be to have a list of all the known torque specs. Anyone care to start? Link to comment Share on other sites More sharing options...
2_From_NH Posted January 7, 2017 Author Share Posted January 7, 2017 I found a thread (Herel) that said the torque (on a 4th gen?) that states it's about 120 ft/lbs. That doesn't sound right. Could someone please verify? My 2800lb MR2 requires 188 ft/lbs front and rear. I'd think it would be more with a heavier car? Link to comment Share on other sites More sharing options...
Shadow_419 Posted January 7, 2017 Share Posted January 7, 2017 5th gen service manual calls for 114 ft-lbs for front strut to hub bolts. Link to comment Share on other sites More sharing options...
15LegacyRyan Posted January 9, 2017 Share Posted January 9, 2017 If you need to know torque specs you can call the dealer and they'll tell you Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
2_From_NH Posted January 11, 2017 Author Share Posted January 11, 2017 If you need to know torque specs you can call the dealer and they'll tell you I hadn't even thought of that. I don't have a very high opinion of dealerships. But, I will say, the few times I've dealt with the Subaru people here, I've come away impressed. When I ACTUALLY LOOKED at the bolt, I understood why it was so low compared to my MR2. It's lobed, whereas my MR2 isn't, so it relies on sheer torque to hold it all together. But, I was pretty happy seeing how easy Subaru made it to dial in alignment settings. Front tie rods are 1 turn for 1mm change, rear toe is lobed with markings, front camber is lobed with markings. If it weren't for the other aspects of this car, it would almost seem like Subaru had sportiness in mind! Link to comment Share on other sites More sharing options...
