catz4dave Posted December 16, 2016 Share Posted December 16, 2016 Recently tried to use cable chains on my 05 LGT wagon, long story short they broke and tore up the back wheel wells of my beautiful car. There is some wiring and tubing in the back of the left rear well that is torn up, does anyone know what these are for? Also how much do you guys think moderate to severe paint chips on my right back wheel well would be to fix, the chains tore paint away in an arc across the well; and its silver LGT stock paint. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted December 16, 2016 Share Posted December 16, 2016 Go get a estimate from a body shop. Next time buy snow tires. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
catz4dave Posted December 16, 2016 Author Share Posted December 16, 2016 Helpful! Link to comment Share on other sites More sharing options...
Max Capacity Posted December 17, 2016 Share Posted December 17, 2016 Pretty much. There is an ABS wire on the LCA. If you want an estimate from me, I'd guess $800-2500 depending on the damage and what you want done to get it back to perfect. With out pictures its hard to tell. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
