Stevh0 Posted December 12, 2016 Share Posted December 12, 2016 I see Avo is selling a 20mm Swaybar without bushes for about 90USD. This seems cheap when compared to Whiteline. Does anybody have experience with the Avo bars? Can I run the 20mm with stock end-links? Link to comment Share on other sites More sharing options...
98legwag Posted December 12, 2016 Share Posted December 12, 2016 There are few people running AVO sway bars on here. Personally I have the 20 JDM rear sway bar. I ran it with stock end links for a little while. I would recommend getting the AVO rear sway bar mount reinforcement brackets too. The stock mount is known to be a weak point. Link to comment Share on other sites More sharing options...
shralp Posted December 12, 2016 Share Posted December 12, 2016 Great upgrade for your outback, just put the AVO on my 08 and it's dialed down some of the crappy under steer that these cars come with. You really want to do the swaybar brackets at the same time though as the stock ones are weak and will probably twist over time. Could use stock endlinks but again they are weak as well when paired to the beefier bar. I chose to put inexpensive Moog ones in and they are much beefier than the stockers Link to comment Share on other sites More sharing options...
