whitrzac Posted December 4, 2016 Share Posted December 4, 2016 I had a coil pack fail when I was ~60+ miles from home. Happened just after a 3/4 throttle pull onto a highway. Engine started misfiring and I suspected the worst. It was violently shaking at idle and under load when <3k rpm. Above 3k it was ok. Got home, inspected injector, plug and put a borscope in the cylinder. No visible damage. Moved coil to another cylinder, problem followed the coil. No random misfires, no other warning. Has anyone experienced this before? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 4, 2016 Share Posted December 4, 2016 Moved coil to another cylinder, problem followed the coil. I think you have a bad coil. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
