Jimmye212 Posted November 29, 2016 Share Posted November 29, 2016 My car is almost completely put back together after a head gasket job. Nothing mechanical inside the engine was replaced, since everything looked good. The pistons and cylinder walls got cleaned up and the new head gaskets are in and everything is sealed with ARP head studs. All other seals and gaskets that are included in a head gasket set were also replaced. I've also included a few other upgrades, but nothing to do with the engine. I've searched the forums but can't find information on break-ins after just a head gasket change. Will I need to do a break in procedure once it is all finished? If so, I'm planning on using Castrol GTX 5w-30 and changing it at the break in intervals and then switching back to my normal oil, Rotella T6. Or is it fine to just continue using Rotella T6 without a break in period? Thanks! Link to comment Share on other sites More sharing options...
RustyRuu Posted November 29, 2016 Share Posted November 29, 2016 The pistons and cylinder walls got cleaned up. Thanks! Define cleaned up? Walls were honed? You took your old rings off and didn't replace them? If they came out at all then you will have to break that sucker in again. Link to comment Share on other sites More sharing options...
Jimmye212 Posted November 29, 2016 Author Share Posted November 29, 2016 Sorry, I should have been more clear. I simply meant that the carbon deposits were cleaned off. I'll add some photos Link to comment Share on other sites More sharing options...
RustyRuu Posted November 29, 2016 Share Posted November 29, 2016 If the piston were not removed you should be in the clear, unless you wanna do some break in intervals if you were working in the wind or a dusty place with lots of people traffic to be sure it's real clean then go for it. Link to comment Share on other sites More sharing options...
Jimmye212 Posted November 29, 2016 Author Share Posted November 29, 2016 Okay thank you. The pistons were not removed. I've attached some pictures. Should I maybe do conventional oil for 300 miles or so then switch back to the synthetic Rotella T6 and call it a day? Or just stick with the Rotella Link to comment Share on other sites More sharing options...
Max Capacity Posted November 29, 2016 Share Posted November 29, 2016 No break in is needed. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Jimmye212 Posted November 29, 2016 Author Share Posted November 29, 2016 Okay, thank you! Link to comment Share on other sites More sharing options...
