georgian Posted November 19, 2016 Share Posted November 19, 2016 hello . my name is rezo shekiladze. im from Georgia not from USA . i got my new subaru legacy 2007 . with 6mt transmission , in the sheet was text about engine. ENGINE NOISE . but in the speedometter is everything ok . no chek engine . http://i84.fastpic.ru/big/2016/1119/8b/f3f1d011233998160b9a4be0e114db8b.jpg i will get my car after 10 or 15 days . it is in Black sea now. i have question for everyone . What is your version ? What kind of damage can be with ENGINE noise ? it is my first post on legacygt.com if topic is offtopic please change toppic and do not ban it. Link to comment Share on other sites More sharing options...
georgian Posted November 19, 2016 Author Share Posted November 19, 2016 http://i84.fastpic.ru/big/2016/1119/3b/eef590f619909210efa8e8fbecaf423b.jpg Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted November 19, 2016 Share Posted November 19, 2016 Diagnosing engine noises over the internet is near impossible. It could be a rod knock of doom or a squeaky pulley. We have zero way to tell at this point. Link to comment Share on other sites More sharing options...
georgian Posted November 19, 2016 Author Share Posted November 19, 2016 I want get ideas . If engine is dammaged and has a knock. Why is not check engine lamp on ? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2016 Share Posted November 19, 2016 It may be to use after the bearing has spun for the metal pieces to block filters in the banjo bolts. Once you get it. You need to get a understanding of the noise before you start the engine and do more damage. Oh yea, welcome to the forum, you've come to the right place. I'll assume the car has a 2.0 liter turbo charged engine ? More info will help us give you more things to look for. We tell most new members to pull the down pipe and check the turbo for shaft play. Its pretty much if you can feel the shaft move more then almost nothing, its bad. There should be very little to no movement, up/down, side to side, in/out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
georgian Posted November 19, 2016 Author Share Posted November 19, 2016 Yes my new legacy is from japan . 2.0 turbo charged. Car is in the best condition , exterior and interior too. One owner , 116K km. But in the latter istext. Engine noise. I m thinking if engine is in bad condition and if we have knocking , on the dasboard we must see ceck engine lamp. But it is not. Link to comment Share on other sites More sharing options...
georgian Posted November 19, 2016 Author Share Posted November 19, 2016 at first i will check turbonetic condition. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 20, 2016 Share Posted November 20, 2016 It could be as simple as a bad AC idler pulley too as said in post 3. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
georgian Posted November 20, 2016 Author Share Posted November 20, 2016 thanks for reply . i hope the best . i hope engine noise is from bad AC idler pulley. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted November 20, 2016 Share Posted November 20, 2016 It can be anything, you're going to have to take it to a mechanic. If the knock sensor is picking up knock then yes it should show a check engine light, but nothing is perfect. The fact that you are saying "noise" is a big problem when trying to help as well, because that's too much of a generic term. Link to comment Share on other sites More sharing options...
StkmltS Posted November 23, 2016 Share Posted November 23, 2016 Some problems will cause check engine light ("CEL"), some problems will not cause CEL. Open the hood (bonnet) and record video. Sometimes we can guess after we hear the noise. არ დაუშვას ენის იყოს პრობლემა. თუ თქვენ გაქვთ შეკითხვები, ჩვენ შეგვიძლია დაგეხმაროთ ზოგჯერ Google translate My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
georgian Posted November 24, 2016 Author Share Posted November 24, 2016 thanks StkmltS i will get car after 5 or 7 days . i hope everything in engine is ok . Link to comment Share on other sites More sharing options...
StkmltS Posted December 21, 2016 Share Posted December 21, 2016 Do you have your car? My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
georgian Posted December 22, 2016 Author Share Posted December 22, 2016 i have got bad surprise http://www.picz.ge/img/s4/1612/22/b/bdbebb31b30c.jpg http://www.picz.ge/img/s2/1612/22/0/00b3aef3fa2f.jpg http://www.picz.ge/img/s1/1612/22/a/a2fad8fabfab.jpg when car was in port, while i go to port for car , someone make a fun with my car , withought engine oil . http://www.picz.ge/img/s1/1612/22/a/a23b966931c7.jpg i get huge loses . but buy new engine and it is ok now <3 . http://www.picz.ge/img/s2/1612/22/a/ac11595e2c6b.jpg i have now 0.9 bar in 2 speed it is normal ? in sport # Link to comment Share on other sites More sharing options...
georgian Posted December 22, 2016 Author Share Posted December 22, 2016 http://www.picz.ge/img/s2/1612/22/9/9258cba921a2.jpg Link to comment Share on other sites More sharing options...
StkmltS Posted December 22, 2016 Share Posted December 22, 2016 :eek: :eek: :eek: I'm glad you have the money to fix the engine and keep the car on the road. Very pretty car! My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
