Logibear117 Posted November 18, 2016 Share Posted November 18, 2016 My 1998 legacy GT's handbrake is very "loose". Not much stopping power from it even when it is pulled all the way. (When just idle, the car still moves unless the lever is pulled all the way) I am almost certain that the problem is due to the adjustment being off because I bought it from an old lady who I'm sure was not skirting around any hairpin turns wearing them out. Lol. I would appreciate a good description of how to set the sensitivity higher or any referral to videos on how to do so. Thanks! Link to comment Share on other sites More sharing options...
Brighton96 Posted November 18, 2016 Share Posted November 18, 2016 There is an adjustment you can make. The cables run to the back of the hub assemblies on the rear of the car and there is a long threaded fitting on the cable, all you have to do is "unscrew" it counter clockwise to tighten up the cable. Keep in mind, if it's loose that most likely means the emergency brake pads are wore out. Link to comment Share on other sites More sharing options...
Logibear117 Posted November 19, 2016 Author Share Posted November 19, 2016 Alright, thanks for the help! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Brighton96 Posted November 19, 2016 Share Posted November 19, 2016 Sorry, I don't have pictures but it's a really easy job, maybe 10 mins a side Link to comment Share on other sites More sharing options...
