Danger Posted November 12, 2016 Share Posted November 12, 2016 I just replaced my power steering pump today with a rebuilt one, put everything back together, and after the car ran for a few minutes I started getting fluid spraying out of the banjo bolt hose. Is there anything as far as O-Rings or anything that this needs? I re-installed the weird metal washer that's like two washers connected together. Could that need to be replaced? I can't really figure out what I did wrong, but I want to have some kind of plan of attack before I take the hose back off and make an even bigger mess. Link to comment Share on other sites More sharing options...
PeterJMC Posted November 12, 2016 Share Posted November 12, 2016 You generally always want to replace metal washers like that with new ones. They get flattened and deformed once you torque them to spec. Link to comment Share on other sites More sharing options...
whitrzac Posted November 13, 2016 Share Posted November 13, 2016 Banjo bolts usually have 2 copper washers. 1 on each side of the pipe. Sometimes they get stuck on the bolt itself. They are generically sized, and are used on brake parts as well. You can pick up a new pack of random sizes for a few $$$ at any auto parts store. Link to comment Share on other sites More sharing options...
jwag74 Posted November 13, 2016 Share Posted November 13, 2016 I couldn't find the factory washers after I put my motor back in and tried rubber O-rings. They won't hold the pressure, after a few seconds they leaked like a sieve. I ended up going to the local hardware store and buying two copper washers, worked like a charm. Assuming you have another vehicle or someone can run you to a hardware or automotive store just take the banjo bolt with you to size the washers. Link to comment Share on other sites More sharing options...
Danger Posted November 13, 2016 Author Share Posted November 13, 2016 I took the banjo fitting back off and replaced the factory "combined" washer and put on two new copper washers, one on each side of the banjo fitting. It STILL drips from between the power steering pump outlet and the banjo fitting. I don't get it. Torqued it to 29lb-ft, which is what I believe the FSM specified. Anyone have any advice? I'm so confused. Link to comment Share on other sites More sharing options...
Danger Posted November 13, 2016 Author Share Posted November 13, 2016 Attached is the bolt with the new washers, what am I missing? It drips like hell as soon as I start the car. I just re-torqued it a bit harder, no change. Link to comment Share on other sites More sharing options...
PeterJMC Posted November 13, 2016 Share Posted November 13, 2016 Take out those copper washers. This is mine (see pic) Where is your double washer? I don't see the rings in your pic. Link to comment Share on other sites More sharing options...
whitrzac Posted November 14, 2016 Share Posted November 14, 2016 Did you clean it off first? Possible cracked? Link to comment Share on other sites More sharing options...
Danger Posted November 14, 2016 Author Share Posted November 14, 2016 I ended up fixing my leak, I think. I went to Advance Auto and picked up some drain plug washers that have a little rubber ring in the center of the washer so they seal against the inside of the bolt. I also made sure that I cleaned all surfaces while I had everything apart. So far so good. ...now my upper hose is leaking slightly, need to figure that out, but at least I'm not spreading fluid all over my engine bay. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2016 Share Posted November 14, 2016 I guess you missed this, http://legacygt.com/forums/showthread.php/power-steering-pump-replacement-05-09-218879.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Danger Posted November 14, 2016 Author Share Posted November 14, 2016 I did miss that, it would have saved me some time for sure. Not sure why that didn't come up when googling, guess I should have had the sense to look in the Walkthroughs section though. Link to comment Share on other sites More sharing options...
