whatsausername Posted November 10, 2016 Share Posted November 10, 2016 Hey everyone I just had my compression test done as I was damn afraid something could've been wrong with my engine. Test results Cyl 1 130psi Cyl 2 145psi Cyl 3 145psi Cyl 4 145psi Car has 110k miles and is "stage 3" no loss in oil, coolant, no smoke from oil filler cap etc. I'm just wondering if these numbers are ok ? Well the 130 psi is bothering me the most as it's 15 less than the others. Thanks for the input. Link to comment Share on other sites More sharing options...
coldsoda Posted November 10, 2016 Share Posted November 10, 2016 Acceptable range is 142-171 psi; difference between cyls should be less than 7psi. Looks like you're in for a rebuild... Link to comment Share on other sites More sharing options...
