Collin9338 Posted November 4, 2016 Share Posted November 4, 2016 So I got a really good deal on a set of aluminum spec b rear trailing arms. I take the driver side completely off and when I go to put the hub onto the aluminum arms the bolts aren't long enough, the spec b arms are thicker in that location so does that mean that I need new hubs from a spec b or just longer bolts? Link to comment Share on other sites More sharing options...
legacybt Posted November 4, 2016 Share Posted November 4, 2016 Longer bolts, the hubs are the same. Link to comment Share on other sites More sharing options...
WRX USA Posted November 4, 2016 Share Posted November 4, 2016 http://opposedforces.com/parts/legacy/us_b13/type_12/suspension_and_axle/rear_suspension/illustration_5/ #25 or #27 Link to comment Share on other sites More sharing options...
Collin9338 Posted November 4, 2016 Author Share Posted November 4, 2016 http://opposedforces.com/parts/legacy/us_b13/type_12/suspension_and_axle/rear_suspension/illustration_5/ #25 or #27 27, its off of an 08 spec b, and mine is an 09 legacy NA Link to comment Share on other sites More sharing options...
Collin9338 Posted May 2, 2017 Author Share Posted May 2, 2017 Hey update, i got the longer bolts, exactly what i needed, problem is i kinda stripped about a half inch of threads of the main bolt going into the frame at the front of the arms... any advice? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 2, 2017 Share Posted May 2, 2017 (edited) Can you run a tap through the threads ? then get a new bolt. is that bolt 26 ? Edited May 2, 2017 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
zactek Posted May 4, 2017 Share Posted May 4, 2017 If the trailing arms are thicker at the hub area,does that mean the hub sits further out on the spec B? The axle spline area limits how far in the hub sits... Zack K. Link to comment Share on other sites More sharing options...
ktm200 Posted September 30, 2021 Share Posted September 30, 2021 (edited) If the trailing arms are thicker at the hub area,does that mean the hub sits further out on the spec B? The axle spline area limits how far in the hub sits... Zack K. Heck of a thread revival but did you ever get this question answered? If you're swapping these trailing arms over do you need longer or shorter axels to account for the different trailing arm thickness? I have a 5EAT I was looking to swap the rear arms on. Didn't want an expensive surprise by realizing my stock axels won't work. Edited September 30, 2021 by ktm200 Link to comment Share on other sites More sharing options...
ttnio Posted October 2, 2021 Share Posted October 2, 2021 perhaps the gain will not justify going through all that trouble... Link to comment Share on other sites More sharing options...
whitexc Posted October 3, 2021 Share Posted October 3, 2021 Longer bolts worked I believe....it was in another thread....? Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
ktm200 Posted October 3, 2021 Share Posted October 3, 2021 perhaps the gain will not justify going through all that trouble... I’m aware that I likely won’t notice a difference. Not really why I’m doing it. Pulling apart the rear of a car that has seen 200k of New England winters is likely going to be trouble as well. Just the fact that it’s be easier in labor to swap in low mileage trailing and control arms opposed to pressing out and replacing all the old, likely seized, bushings is worth it to me. Price was not too much more than just buying all new bushings, and I don’t have a press so might have needed to add in some shop labor hours. Link to comment Share on other sites More sharing options...
Code Posted October 3, 2021 Share Posted October 3, 2021 I just ordered a complete set of hardware for my trailing arm swap. I can get you all the part number and quantities when I get home. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
ktm200 Posted October 3, 2021 Share Posted October 3, 2021 I just ordered a complete set of hardware for my trailing arm swap. I can get you all the part number and quantities when I get home. Thanks, I’d appreciate that. Link to comment Share on other sites More sharing options...
