ccgoogins Posted October 29, 2016 Share Posted October 29, 2016 Is the "Warrenty & Maintenance Booklet" for a 2015 Legacy 2.5i available online to download anywhere? I purchased this used car 10 months ago from a dealer that is about an hour away, so along with the hassle of driving all the way out there, I am assuming the dealer is not going to be all that motivated to give me one. I believe I have all the other needed manuals. I have the "Owners Manual", which just says - "see the Warrenty & Maintenance Booklet" - for this subject. While MySubaru.com has copies of other manuals, such as the Owners Manual, it does not have a copy of the Warrenty & Maintenance Booklet. And, while MySubaru.com also has lists for each maintenance milestone, it often skips whether you are suppose to replace or just inspect the item. Thanks. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 30, 2016 Share Posted October 30, 2016 http://www.subaruoutback.org/forums/138-gen-5-2015-present/280682-2016-owner-s-service-manuals-posted.html check that out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DrD123 Posted November 12, 2016 Share Posted November 12, 2016 good info here, too http://legacygt.com/forums/showpost.php?p=5500527&postcount=396 Link to comment Share on other sites More sharing options...
