javapop Posted October 20, 2016 Share Posted October 20, 2016 Just got a used 05 Legacy Outback, and we got a great deal; but didn't notice a few things until after back in Georgia... and sale was complete. Very happy with the car, just need to fix this particular issue quickly! The remote key lock isn't working. I did see something about programming it in the manual (glovebox version). Do I just have a bad one; OR is the fact that my drivers side Door Lock Actuator doesn't seem to be working either. Also, the rear hatch doesn't lock, at all. Thats seriously an issue. Maybe just a new rear hatch Actuator? I checked the wire cluster going into the back hatch, no visible wires broken. Advise, would be greatly appreciated! http://david.stembridge.us/media/_LLS9528_FB-1.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted October 20, 2016 Share Posted October 20, 2016 There is a battery in the key fob, do you replace it ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
javapop Posted October 21, 2016 Author Share Posted October 21, 2016 There is a battery in the key fob, do you replace it ? I did; but when I opened to clean and inspect noticed the 2 main switches had come unfastened from the little circuit board. So, I have ordered a new one via eBay! I also ordered a new driver side door Actuator as well. Mine isn't working. I checked the rear one, and it looks great, well lubed and no rust or broken wires. Once the new Actuator is installed, the rear hatch should respond properly. I'll update here when I get everything and install it! Link to comment Share on other sites More sharing options...
