mis08011 Posted October 18, 2016 Share Posted October 18, 2016 Hi all, My car has become noisier over the past week, sounding more like an old John Deere than a recently rebuilt Subaru. I assumed it was an exhaust leak, but the noise doesn't seem isolated to one area and is noisy at idle. Here's the URL to a low-quality, midnight video that I just captured: https://youtu.be/EH6nO25YgYI For additional info, the car is already throwing a CEL from the missing EGT sensor, so I don't know if this new issue is causing any other codes at this time. I appreciate any help you all can provide. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2016 Share Posted October 18, 2016 That sounds pretty normal, injectors firing, is the ticking sound. The rumble sounds like nice exhaust. You'll need to get under the car when its up on jack stands and start the engine. That's how's I found my leak over the weekend 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
