STI_Steve Posted October 16, 2016 Share Posted October 16, 2016 Anyone have a used front strut for a 2010 3.6r or GT? I was trying to do a koni insert job and fucked it up. Sheared the top of the koni cylinder off trying to attach the top hat. I'm so pissed... Link to comment Share on other sites More sharing options...
brandon.mol Posted October 17, 2016 Share Posted October 17, 2016 So you ruined the insert or the donor strut? Link to comment Share on other sites More sharing options...
FLlegacy Posted October 17, 2016 Share Posted October 17, 2016 For the record it doesn't need to be a 3.6 or GT they are all the same IIRC. Link to comment Share on other sites More sharing options...
STI_Steve Posted October 17, 2016 Author Share Posted October 17, 2016 The insert was in the donor strut and the top of the insert piston sheared off when I was trying to tighten the top hat. #atemywheaties Now the insert is jammed in the donor strut and. Have no way of getting it out... Link to comment Share on other sites More sharing options...
FLlegacy Posted October 17, 2016 Share Posted October 17, 2016 Yes you do, unscrew the bolt and tap the bolt head to get it out, you may need a longer bolt to get it all the way or just use a punch or screwdriver. Sounds like you didn't cut enough of the strut body off. Either way the insert is done, I would be though you can send it in to Koni for repair/rebuild. Link to comment Share on other sites More sharing options...
