zero260 Posted October 14, 2016 Share Posted October 14, 2016 So I swapped rotors and brackets to the 2000 h6 290mm but used my original calipers with new bolts and hardware. The caliper bolts were really hard to line up and now the calipers are hanging up and I think it's the caliper to bracket alignment, I don't thing the calipers ate letting of the pads. From what I read the swap just needs rotors and brackets? Do I need the calipers to? Link to comment Share on other sites More sharing options...
whitetiger Posted October 14, 2016 Share Posted October 14, 2016 what was the purpose of this swap? seems counter productive. Link to comment Share on other sites More sharing options...
zero260 Posted October 14, 2016 Author Share Posted October 14, 2016 Besides the issue I have it's supposed to be a straight up swap, and the rotors are almost an inch larger. But if you NEED calipers the lgt swap is better, which I would do instead. I'm trying to upgrade on the cheap Link to comment Share on other sites More sharing options...
whitetiger Posted October 14, 2016 Share Posted October 14, 2016 you can buy really cheap loaded calipers and rotors for the LGT from rockauto. Link to comment Share on other sites More sharing options...
