Shift linkage broke
Black08LGT
So I pulled into a parking spot today and when I went to put the car into reverse the shift felt strange. I tried going to 1st and still strange. Then it finally dawned on me the stick is completely loose and I couldn't feel a single gate. I tore of the boot to inspect the linkage underneath and everything looked kosher. I noticed that the rod running from the shift base to under the AC controls (towards the driver's side under the dash) was just completely free on the end under the dash area. I looked under the car and found a roll pin. Can anyone point me into the right direction to fix this? I had the car towed home but so far I haven't had anytime to look things over or do much research. Roll pin picture attached (penny for scale).
http://people.csail.mit.edu/ilh/vacation/
The service manual should help.
Just drive that pin back in where it goes.
You may have to unbolt the shifter and do this on a bench.
May be a good time to upgrade to a short throw shifter. Kartboy or Cobb.
Engine Build - Click Here
Max thanks for the info. I ended up buying a replacement pin at the dealership today just in case the pin was faulty.
I noticed that there is a hole (indicated by the red arrow) in the side of the bracket (light blue) holding the shiftier bushings together. In the manual it does not look attached to anything but I wanted to make sure it in fact doesn't do anything before buttoning things up on the car. Anyone know, does the hole do anything? The bracket (light blue) can freely rotate with minimal effort.
For future reference if anyone else runs into similar issues. I put the two pieces back together, aligning the holes, and used a nail to hold it together. Then I put the car in 5th gear which moved the hole forward and rotated it CW (allowing better alignment to drive the pin - away from the tranny support). Then I coated the pin in caliper glide pin lube and placed it inside a shallow socket that just fit the pin OD. I used a long extension and a large hammer to drive the pin into place. Near the end I had to switch to a larger hammer to finish driving the pin.
Yep, that tab/hole is there just to make you think...
It's really something the Japanese do to screw with us stupid American's...;)
I recall Honda Civic's had some funky things that no one could figure out what they were for.
  • 1 month later...
Any advice on getting the pin out? The manual just says 'extract the pin', which suggests there's a special tool? I'd really rather not remove it as it's fine but I have to replace the bushings on the adjacent link and the bolt is facing the driveshaft, so it's not coming out even if I get it unscrewed. I have a spare pin so I don't really care if I trash the one in there. Also, there seems to be some sort of pin on top that inserts into the pin shown on the diagram but there's no reference to it in the drawing or ass/disass instructions.
Well, as that baggy pants'ed rapper says: "Hammer Time!". I took a screw with an ID that would fit inside the pin and a head that was large enough to push the pin thru but small enough to go thru the hole. I greased it up real good so it would stay inserted and just hammered away until it came out. I have a new one so I wasn't concerned about trashing it.
  • 3 years later...
how did you hammer the pin out? from underneath? i mean..just hammer?? i'd tried but the pin seemed didn't move a bit. is this the pin in the pic (just make sure :icon_lol: )
Mark, I never hammered out the roll pin. In my case it just fell out one day while pulling into a parking spot. It's been a few years but from what I recall it was pretty cramped under there. Your picture looks like it's taken from the opposite side as mine but I think you are looking at the same pin. It's going to be a real PITA to hammer out that pin. You want to find something to tap the end with, like a punch. See this video if some ideas
