WTFBoxer Posted October 6, 2016 Share Posted October 6, 2016 So I'm driving home from work today, car is set on cruise at 80. Currently have a BNR 18G. Car was running fine, no issues. Tap the breaks to get off the off ramp and I notice it's seems to be running a little rough. I come to a stop at the bottom of the off ramp. See some oil smoke in the mirror and poof it shuts off. Thought it was a head gasket but saw the oil smoke and thought different. Started it up and limped home. Got it home and started it one more time. No noise from the turbo and still seems to build boost but it is blowing smoke from the BOV when it vents and from the exhaust. This turbo only had about 5k miles on it. Does this sound like a blown turbo to you folks? Link to comment Share on other sites More sharing options...
Grothe08LGT Posted October 6, 2016 Share Posted October 6, 2016 Pull the turbo and check for shaft play Link to comment Share on other sites More sharing options...
Max Capacity Posted October 6, 2016 Share Posted October 6, 2016 What year car? Do you have the required filters in place that Brian say's ? Why was the turbo replaced with the 18g ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tuning Alliance Posted October 6, 2016 Share Posted October 6, 2016 Pull the turbo and check for shaft play Second. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted October 6, 2016 Share Posted October 6, 2016 You can also just pull the down pipe and check for shaft play. If you have more then very little then pull the turbo and think about having it rebuilt and replaced. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
