5280Autoworks Posted October 12, 2005 Share Posted October 12, 2005 We would like to introduce ourselves. We are opening a new shop in the North Denver area and are looking for clients. We prefer to take the time and try to figure out what the client is going to be doing with his car and how that might effect what parts and packages we suggest. How much money is this client looking to spend at this particular time? This sometimes requires a lot of time. We prefer to give the client some options and let them decide which ones they prefer based on what is important to them. A clients car, takes what ever time, it takes. You really can not flat rate “quality” performance work. If you did performance work on a flat rate basis you would be spending about $400.00 to $750.00 for a spring install and alignment and that doesn’t include the cost of the parts. An up pipe would run you well over $500.00 for just the labor. Not our way of doing things, sorry. We believe in charging fairly for what services you are providing. A client brings you their car for several reasons. 1. You have the experience that they may lack as you may have installed this item several times. 2. You have the knowledge to make all the items work correctly together. Many items will physically bolt to each other but they may have adverse effects that will cancel out any benefits you thought you were getting. 3. You have the facility to install it, modify it, or build it. 4. There time is better spent doing something else. Sometimes it is just more convenient for them to just drop it off and pick it up when it is ready. We are working on the one client, one car principal. We also offer valet service, pick up and delivery option. We are a small shop and will do our best to provide you with quality work at a fair and reasonable price. Some Examples of Installations are: Custom Welding (BTO systems or modifying front mount intercoolers) $ depends on what you are after Turbo component repair (fix leaks in welds on up or down pipes) starting at $75 7500 mile service, 15k, 30k, 60k, services (only use genuine Subaru parts) Timing belts, water pumps, oil pump reseals. Up-pipe $225.00 Down Pipe $75.00 Coil over suspensions or just struts or springs starting at $300.00 Big brake kits starting at $200.00 Our new web site will be operational very shortly and we will be posting better descriptions, prices, packages, and more as soon as possible. We can get letters of recommendation if requested. Joseph Cox sales@dealertuningservices.com 720-364-4227 AIM: Autoworks 5280 Dan Zamora Dan Kim 720-217-3193 AIM: Autoworks1 5280 Link to comment Share on other sites More sharing options...
PGT Posted October 12, 2005 Share Posted October 12, 2005 Please see the vendor page before posting: http://legacygt.com/forums/showthread.php?t=19483 closed. Link to comment Share on other sites More sharing options...
