ipekur Posted October 2, 2016 Share Posted October 2, 2016 Hi, I searched all over but can not find information on where the starter/ignition relay is located. The starter does not turn when clutch is pressed. I removed the starter ant tested it - it is working. I checked the cables and ground is connected to ground in thew car and positive connects to battery positive. So only electrical issues are left. I can only think that relay and clutch switch could be culprits. Please let me know your suggestions and is you know where ignition/starter relay is. Next to the breakers in the driver footwell, there are 2 columns of relays. There is nothing for ignition in the relay/breakers box under the hood. Any advice would be appreciated! 2006 Legacy GT 5 speed manual Link to comment Share on other sites More sharing options...
ehsnils Posted October 2, 2016 Share Posted October 2, 2016 Ignition lock would be the first item on the check. And look in this thread: http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html Link to comment Share on other sites More sharing options...
Max Capacity Posted October 2, 2016 Share Posted October 2, 2016 The service manual may help http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
