cerbomark Posted September 28, 2016 Share Posted September 28, 2016 Is the rear sway bar the same part as the Legacy? Same stock size as Legacy? 19MM would be an upgrade then correct? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted September 30, 2016 Share Posted September 30, 2016 There are threads about the rear sway bar upgrade on here and over on www.subaruoutback.net Seem to recall its actually a STi rear sway bar. Some with an Outback go for a 20mm bar because of the rear glass weight. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTEASER Posted September 30, 2016 Share Posted September 30, 2016 2011-2014 STi RSB is 19mm. 2015+ STi RSB is 20mm. As Max said, I would go with the 20mm bar at an absolute minimum on an Outback because of the extra weight that the wagon has high up in rear. Click the 2009 XTEASER link in my signature to go to my Forester XT build thread. The part numbers for the 20mm STi RSB and bushings are on the first page. It will be a direct fit to your car. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Max Capacity Posted October 4, 2016 Share Posted October 4, 2016 Also this is covered over on www.subaruoutback.org http://www.subaruoutback.org/forums/104-gen-4-2010-2014/24867-sway-bar-mod-picture-tutorial-91.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cerbomark Posted October 11, 2016 Author Share Posted October 11, 2016 Thanks for all the info.. Just ordered a 19MM for the outback. Already have one on my legacy. anyone need the smaller bar, I now have two, LOL. Link to comment Share on other sites More sharing options...
