ktm200 Posted September 27, 2016 Share Posted September 27, 2016 Have been using the Purolator PureOne for a few years now, the yellow one with the grippy coating, PL14162. Went to pick one up today at advance auto parts and it's a new version with the same part number. Just called purolator one. Blue with a smooth finish. Here is the old yellow: http://m.advanceautoparts.com/h5/r/shop.advanceautoparts.com/p/purolator-pureone-oil-filter-pl14610/5700001-P And the new blue: https://www.amazon.com/Purolator-PL14612-PurolatorOne-Oil-Filter/dp/B000E8T81U Anyone else come across this swap? Sales associate said the yellow ones are being discontinued. Kind of a bummer. Big fan of the grip when I'm taking them off. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 27, 2016 Share Posted September 27, 2016 I use a Vibrant silicone hose coupler that slips over the smooth filter and gives you a nice grip. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitrzac Posted September 27, 2016 Share Posted September 27, 2016 The blue grippy ones have been discoed too... time to find a new filter brand. Link to comment Share on other sites More sharing options...
pseank Posted September 28, 2016 Share Posted September 28, 2016 I use Subaru filters on all my subies especially my lgt because I know the bypass is properly calibrated. That said I use AC delco on my 86 Chevy k10 AC delco on my 93 Chevy powered Mercruiser blue water inboard and Purolator on my Samurai because Suzuki changed theirs and the new ones bottomed out metal to metal hand tight. Always oem when I can... Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
Phate Posted September 28, 2016 Share Posted September 28, 2016 I use Mazda RX8 oil filters or Subaru Blue's on the legacy. The accord gets Purolator classic/napa wix filters because I don't care. GF's Fit gets the newer expensive Purolators because tiny low-power engine with synthetic oil and long OCI's. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 28, 2016 Share Posted September 28, 2016 Another trick I've used in the past, line the inside of the metal band/strap wrench with double back masking tape and stick some 80 grit sandpaper to the it. That will grip the filter. I have also found that if you install the filter correctly by hand, it will come off by hand. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
quick4dr Posted September 28, 2016 Share Posted September 28, 2016 On by hand off by hand, I usually brake it loose then put a solo cup over it as I unspin it so the oil drains in the cup and not my manifold wrap. Then I clean the surface lube my new oil filter seal, prefill my Tokyo Roki filter and then thread it on till snug, plus a little turn. no leaks Link to comment Share on other sites More sharing options...
TECouz13 Posted September 28, 2016 Share Posted September 28, 2016 It's the same filter just marketing the pureone has changed looks a few times over the years. They just launched a new BOSS filter as well. Link to comment Share on other sites More sharing options...
doobaruGT Posted October 5, 2016 Share Posted October 5, 2016 Have been using the Purolator PureOne for a few years now, the yellow one with the grippy coating, PL14162. Went to pick one up today at advance auto parts and it's a new version with the same part number. Just called purolator one. Blue with a smooth finish. Here is the old yellow: http://m.advanceautoparts.com/h5/r/shop.advanceautoparts.com/p/purolator-pureone-oil-filter-pl14610/5700001-P And the new blue: https://www.amazon.com/Purolator-PL14612-PurolatorOne-Oil-Filter/dp/B000E8T81U Anyone else come across this swap? Sales associate said the yellow ones are being discontinued. Kind of a bummer. Big fan of the grip when I'm taking them off. I noticed this nearly 6 mo ago. I called purolator and they said it just had to do with a supplier part change. Essentially, it was just superseded. I don't know if that necessarily means improvement, but the box indicates the same filtering ability. I was forwarded to one of the engineers but I never got a response from him. I left the vm while he was on vacation so I probably just slipped through the cracks and I never cared enough to pursue it any further. The blue grippy ones have been discoed too... time to find a new filter brand. I hadn't heard this. Oh well... We just bought a '17 FXT for my bride so I'll likely make the switch to the Subaru filters, though I thought there was chatter some time back about them going subpar on quality. I'll have to see what I can dig up. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
ktm200 Posted October 5, 2016 Author Share Posted October 5, 2016 Thanks for the replies guys and thanks for the suggestions MaxCapacity. The change isn't a deal killer, just preferred the old housing design. Also like the solo cup idea, hate that the filters always leak all over the place. I used to use the oem filters way back but really hate my local dealership so I switched to Purolator based on quite a few threads I saw here. Thought the bypass valve was pretty close to oem and a little more filter capacity. Know I can order oems online, but just convenient grabbing something available close by. Link to comment Share on other sites More sharing options...
acumenhokie Posted October 11, 2016 Share Posted October 11, 2016 Glad to see this thread. I have the same experience as OP and was wondering about those blue filters. For now I bought them and am using them (on my 2nd). I looked a while ago over at BITOG but couldn't find anything. Link to comment Share on other sites More sharing options...
WahooNo2 Posted October 17, 2016 Share Posted October 17, 2016 New number now is pl14615 with the better bypass valve (20-30psi) http://www.pureoil.com/en/do-it-yourself/online-catalog/filter-lookup/ I have been using the fram ultra with metal reinforced media and grippy stuff. If you just want it to be grippy you could spray paint the filters with rubber undercoating or grippy paint or tape. Or use a silicone glove or trivet. https://www.amazon.com/LotFancy-Resistant-Silicone-Barbecue-Textured/dp/B018QLEZ2I/ref=sr_1_1?ie=UTF8&qid=1476747285&sr=8-1-spons&keywords=silicone+gloves+bbq&psc=1 When I change my oil I stab the filters with an awl or pocket knife to drain it. Then I use a styrofoam coffee cup like mc cafe so I burn myself less Link to comment Share on other sites More sharing options...
