Car won't start
Try turning the key three or four times to let fuel pump pump without turning the car on and then turn the car on and see if it runs a little bit that might be your fuel pump that's what happened with my car. The fuel pump is still pumping fuel to prime but wasn't pumping enough to keep the car running. When my pressure regulator went out the car was running fine at idle but high rpm's with stall out.
