Xcyzon Posted September 14, 2016 Share Posted September 14, 2016 i have found part# H001SAJ000 online as a Subaru genuine part remote start - dealer installed. I'm curious if this is actually an available install for the 2.5GT Limited? While I found it on Subaru's site, it doesn't actually say if it's available for a manual transmission...before I call a dealership, I'm wondering if anyone knows...(I'm new to Subaru and love my new-to-me 2.5GT!) Link to comment Share on other sites More sharing options...
Blegacy2.5 Posted September 14, 2016 Share Posted September 14, 2016 Correct me if im wrong but doesn't the 2.5GT only come in a Manual transmission and is this a USDM option? Link to comment Share on other sites More sharing options...
Xcyzon Posted September 14, 2016 Author Share Posted September 14, 2016 it only comes with a manual transmission and this is a dealer installed USDM option - so the remote start would need to somehow bypass the clutch switch and start the vehicle (I'm guessing) when it's parked in neutral. Remote starts are usually only available for automatics I know, but because the GT tells you what gear you're in, I am wondering if it available because the vehicle knows that it's in gear. With that feature, and that it would be integrated into the vehicle's stock system, I'm curious if it's actually possible to install or if anyone has it installed? Link to comment Share on other sites More sharing options...
Byll Posted September 14, 2016 Share Posted September 14, 2016 A number of years ago, a board member made and sold, a small wiring harness that would allow the 5th gen MT-equipped Legacies to be started without depressing the clutch. I am a bit too busy to search for that thread at the moment, but I purchased the device, and it has worked flawlessly for a lot of years. Best. Byll Link to comment Share on other sites More sharing options...
Feeny1701 Posted September 14, 2016 Share Posted September 14, 2016 Subaru will not install remote start on cars with standard transmission. There are aftermarket kits out there to do it, and they usually require some sort of sequence to be completed before you leave the car to enable it to remote start one time. I had an aftermarket alarm on the '08 spec.B I had that had the remote start feature, and I never used it because the arming sequence was a pain in the rear to do every time, and I ended up getting rid of the alarm system because whoever installed it didn't know what they were doing. Link to comment Share on other sites More sharing options...
FLlegacy Posted September 14, 2016 Share Posted September 14, 2016 I believe the viper alarm/remote start or compustar has a module for our cars with the 6mt. The subaru remote start will not work without a work around and then you run the risk of having your car turned into an oops. Link to comment Share on other sites More sharing options...
jertfunk Posted September 14, 2016 Share Posted September 14, 2016 Compustar with idata alca works flawlessly Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Xcyzon Posted September 14, 2016 Author Share Posted September 14, 2016 Thanks for the info guys! I was really hoping there was a factory option - I'm not a huge fan of integrating aftermarket electronics, especially to bypass the factory alarm system. Link to comment Share on other sites More sharing options...
FLlegacy Posted September 15, 2016 Share Posted September 15, 2016 These alarms work with the factory one through modules specific to the vehicle. The factory remote start is not that swift from what I have read and has a few limitations which the aftermarket systems do not. You should talk to a local installer, maybe they can put your mind at ease. Link to comment Share on other sites More sharing options...
Ellesedil Posted September 15, 2016 Share Posted September 15, 2016 It's worth noting that when we leased my wife's Impreza, the local dealer actually installed an aftermarket remote start system. We didn't pick it out; my wife simply requested remote start and the dealer selected the system and installed it. But it definitely wasn't the OEM system. Link to comment Share on other sites More sharing options...
jojorios Posted September 15, 2016 Share Posted September 15, 2016 Link to clutch bypass thread: http://legacygt.com/forums/showthread.php?t=199113 Viper alarm has a setup for MT cars. Sent from my SM-G935F using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted September 15, 2016 Share Posted September 15, 2016 +1 on the bypass. Works great, its just a bit of a pain to install since the space is so tight down by the footwell My "Build" Link to comment Share on other sites More sharing options...
jojorios Posted September 15, 2016 Share Posted September 15, 2016 I've tried about 3 times so far to install it and I've managed to jack my hands up each time. One day i'll get it installed lol. Link to comment Share on other sites More sharing options...
FLlegacy Posted September 15, 2016 Share Posted September 15, 2016 I get the idea of the bypass, I just know that I will be the person who gets in one day and bump starts my car into the fence, lol. Better safe than sorry! Link to comment Share on other sites More sharing options...
brandon.mol Posted September 16, 2016 Share Posted September 16, 2016 I have a drone v2 plus compustar brain in my car. Works great. You can't accidentally start it while in gear. It's impossible, since you have to leave it in reserve mode. The care shuts off after you get out. Useless for those who don't trust the park brake. Link to comment Share on other sites More sharing options...
jertfunk Posted September 20, 2016 Share Posted September 20, 2016 I get the idea of the bypass, I just know that I will be the person who gets in one day and bump starts my car into the fence, lol. Better safe than sorry! It only bypasses the clutch during remote start Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted September 21, 2016 Share Posted September 21, 2016 It only bypasses the clutch during remote start Sent from my iPhone using Tapatalk Not the one linked in the posts to the forum, the remote start systems I would imagine either have a bypass or skip the clutch switch altogether. Link to comment Share on other sites More sharing options...
brandon.mol Posted September 21, 2016 Share Posted September 21, 2016 That's just a DIY hack, not a remote starter. Any decent remote starter bypasses the clutch swith on remote start, and requires the car to be in reserve mode, which means the car was shut off in neutral, with everyone out and the doors locked and park brake set. This means the car has to be in neutral. The only way it may not be is if the window is down and you reach in and pop it in gear... So don't leave your window down while unattended anyway, right? Link to comment Share on other sites More sharing options...
A_A_ron Posted November 9, 2017 Share Posted November 9, 2017 Great info here. Thanks all. I am looking to install a remote starter soon. Anyone have any recommendations besides the Viper? Build Thread Link to comment Share on other sites More sharing options...
brandon.mol Posted November 11, 2017 Share Posted November 11, 2017 Great info here. Thanks all. I am looking to install a remote starter soon. Anyone have any recommendations besides the Viper?I've had a viper with smartstart in my Mazdaspeed 6 and 4 different Compustar+Drone mobile systems. The original version 1 dronemobile receivers were garbage but the newer ones are excellent. Drone mobile service is cheap, too... If you are into the whole start with your phone from far away thing. Currently, I have a gen-2 drone mobile system with compustar brain in my LGT and I have a gen-3 drone mobile system and compustar brain in my SantaFe Sport. Both work very well. Basically the best systems are compustar/drone, viper/smart-start, and Titan. Link to comment Share on other sites More sharing options...
FLlegacy Posted November 11, 2017 Share Posted November 11, 2017 Does the compustar allow entry without shutting off the vehicle? And instead of the oem key fob you use the aftermarket or both? Link to comment Share on other sites More sharing options...
A_A_ron Posted November 13, 2017 Share Posted November 13, 2017 Does the compustar allow entry without shutting off the vehicle? And instead of the oem key fob you use the aftermarket or both? Good Question! From what I have read in the manual for the 2way system it emphasizes that you cannot put your foot on the brake before inserting the key and turning it to the on position otherwise it will kill the engine. This tells me that you do not have to shut if off before getting in and driving. Build Thread Link to comment Share on other sites More sharing options...
robburns201 Posted November 13, 2017 Share Posted November 13, 2017 I'M getting the 2way Python remote start installed on Friday...Its pricey but has a changeable battery (via mini usb) and a turbo timer and smart start if you decide you want to use your phone...1 mile range for the FOB isn't bad either... Link to comment Share on other sites More sharing options...
brandon.mol Posted January 28, 2018 Share Posted January 28, 2018 Does the compustar allow entry without shutting off the vehicle? And instead of the oem key fob you use the aftermarket or both?That entirely depends on the car. Toyotas with push button start shut off. Dunno about Subarus with PBS. My LGT doesn't... You just put in the key and turn it to on. Just don't touch the brake peddle prior. In the Santa Fe with push button start, it's a little different. You just get in the car and touch the brake and it checks for you key and turns to ON without you doing anything. In neither case does the car shut down. I don't use the compustar fob.... It stays at home. Just the key and the drone mobile app on my phone. Link to comment Share on other sites More sharing options...
