Shello007 Posted September 9, 2016 Share Posted September 9, 2016 I know a few of you have experienced this. In the searches, most of you state it has stopped after lubing but mine still persists. The breakdown: The front left Wheel makes a clunk that can be felt through the brake pedal. This only happens at low speeds and maneuvers, and when the brakes are heated. I have taken calipers apart, greased the slide pins and it stops for couple days. Now it's persisting. Any suggestion guys? Can't afford to upgrade to Brembos just yet. Link to comment Share on other sites More sharing options...
TheMonaLisa Posted September 9, 2016 Share Posted September 9, 2016 I seized 4 front calipers in 3 years, two of those were the OEM calipers. Solution was front Brembos. Never seized a rear caliper, still on the OEM rear calipers with 130k. Sorry I have no advice but I feel your pain. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Shello007 Posted September 9, 2016 Author Share Posted September 9, 2016 Lol, thank you. Funny because after posting that thread I immediately started looking for Brembos. Link to comment Share on other sites More sharing options...
TheMonaLisa Posted September 10, 2016 Share Posted September 10, 2016 All of the STI front Brembos from 04-17 are a direct fit btw. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Shello007 Posted September 10, 2016 Author Share Posted September 10, 2016 All of the STI front Brembos from 04-17 are a direct fit btw. Sent from my iPhone using Tapatalk But rotors have to be changed to STi, right? Link to comment Share on other sites More sharing options...
TheMonaLisa Posted September 10, 2016 Share Posted September 10, 2016 But rotors have to be changed to STi, right? Yes and only the 04 STI had the 5x100 bolt pattern like we do so you need 04 STI rotors. Some aftermarket STI rotors are dual drilled for 5x114 and 5x100 which would also work. Additionally you will need the bolts to mount the calipers as the threads are different pitch than our stock bolts and you will need STI brake lines as they are longer than our stock lines. Link to comment Share on other sites More sharing options...
