lh0628 Posted September 3, 2016 Share Posted September 3, 2016 Does anyone know if one can use a H4 oil filter on the H6? Specifically a Wix 57712, aka Napa 7712. Napa lists 1334 as the filter PN for a H6, and the only difference I see in spec is size and bypass pressure. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 3, 2016 Share Posted September 3, 2016 No, that bypass pressure is what's important. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
98legwag Posted September 3, 2016 Share Posted September 3, 2016 I bought a 6 pack of OEM filters for my H6. I will be doing it again. Link to comment Share on other sites More sharing options...
lh0628 Posted September 3, 2016 Author Share Posted September 3, 2016 Thanks guys, I'll stick with the OEM black ones. Link to comment Share on other sites More sharing options...
