ShadowVir Posted August 31, 2016 Share Posted August 31, 2016 Hey Guys! I wasn't to sure on were to post this but i have a few questions regarding my turbo swap. I found a vf39 local for cheap, so i ended up getting every thing else for a swap, fmic, downpipe and up pipe, etc. The question i have is in regards to the tuning. Can i use a accessport to tune this setup? Or do i have to get a protune? If i can use one, which map would i use, a 05 sti map? I thought i was going to have to get a protune but i have a accessport I thought i better ask. Thanks! -SV Link to comment Share on other sites More sharing options...
Max Capacity Posted August 31, 2016 Share Posted August 31, 2016 Pro tune. The Cobb AP will be easier for you to use and data log so the Tuner can give you a custom MAP for your set up. No Cobb tune will work with your set up. I use www.tuningalliance.com for all my tuning needs, He is one of the best with these cars. Really, he's that good. Tell him I sent you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 1, 2016 Share Posted September 1, 2016 I would advising getting a cobb ap, and a custom etune. The cobb ots map don't support "swapped turbos" and open source while viable, won't give you as good as a tune in the end result from limitations. Shoot us a PM and we can discuss process and pricing. p.s thanks Max for the referral! -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
