logankeyes Posted August 28, 2016 Share Posted August 28, 2016 HELP! Installing a mishimoto turbo inlet and going off of the perrin instructions. I'm stuck on the PCV hose. Do I leave the spot in the T open to atmosphere and cap the port on the inlet? do i get an over sized hose to hook into the T and then a hose clamp on the inlet? I've read multiple different ways of doing it. HELP! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 28, 2016 Share Posted August 28, 2016 http://legacygt.com/forums/showthread.php/inlet-removal-write-upi-255576.html that may help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
