ebo03 Posted October 5, 2016 Share Posted October 5, 2016 Avoid DW, especially the 65c. Get a AEM 320lph -Brian Yup. Just a heads up though, I have seen a couple of DW300 pumps fail in about a year of use. Don't know if that's a trend but it's something to look out for. Regular Walbro 342 works in this application but damn there are so many fakes out there now. I had a DW300 for a couple of years. IAG has also had failures with DW pumps so they replaced it with a Walbro. Link to comment Share on other sites More sharing options...
RWebb Posted October 5, 2016 Share Posted October 5, 2016 Did I say boost-a-pump and how it worked great on my car for 10 years Link to comment Share on other sites More sharing options...
fantasyxiv Posted October 6, 2016 Share Posted October 6, 2016 Running a Dw300 as well, recently installed less than 1 week ago. Link to comment Share on other sites More sharing options...
perfweld Posted September 25, 2017 Share Posted September 25, 2017 I'm gonna be converting to E85 when the parts arrive, only a few days on the CA 91 and I cant take it. I bought the ID1050X injectors and the AEM 50-1200 pump. Has anyone successfully used this pump yet ? Also what spark plugs and gap are you guys using on E85 ? Thanks Link to comment Share on other sites More sharing options...
fantasyxiv Posted September 27, 2017 Share Posted September 27, 2017 When I had my 5th gen i use to run the dw300 also having said that my car wasnt as heavily moddifed as you are planing on going, i didn't personally have issues when I was running it via my experience. Link to comment Share on other sites More sharing options...
acumenhokie Posted September 27, 2017 Share Posted September 27, 2017 Also what spark plugs and gap are you guys using on E85 ? Thanks Running NGK plugs but don't know the gap. Link to comment Share on other sites More sharing options...
GTEASER Posted September 27, 2017 Share Posted September 27, 2017 I'm gonna be converting to E85 when the parts arrive, only a few days on the CA 91 and I cant take it. I bought the ID1050X injectors and the AEM 50-1200 pump. Has anyone successfully used this pump yet ? Also what spark plugs and gap are you guys using on E85 ? ThanksFor plug gap, follow your tuner's recommendation. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
perfweld Posted September 28, 2017 Share Posted September 28, 2017 I appreciate the help guys. I was told to use the OEM plugs at the power level im gonna be at, and gap them at .028 I bought the AEM pump and the ID 1050X injectors, those will be here Friday I believe. I plan on changing the parts over the weekend then start the tuning process hopefully next week. I will post whether the pump drops right in or what I need to do to modify. Im not going for big power, just dont wanna deal with our CA 91 fuel and the knock im seeing, E85 is easy to get for me and I use i in my Ecoboost Mustang, so its always on hand. Link to comment Share on other sites More sharing options...
GTEASER Posted September 28, 2017 Share Posted September 28, 2017 I'm interested in the AEM pump as well, so please post a lot of pics and a write up. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
perfweld Posted September 29, 2017 Share Posted September 29, 2017 I had to modify just a few small things for the AEM pump, its taller, and the pickup does not seal to the pump so I used an O Ring to seal it as its being pushed up against it with the spring on the bottom of the pick up. The pump being taller I used safety wire as it would not clip. After I did those modifications it dropped right in. Link to comment Share on other sites More sharing options...
tocinoman25 Posted September 30, 2017 Share Posted September 30, 2017 Just curious, why avoid the DW65c-- bad personal experiences, don't like the brand, or?Im on my 3rd dw65c pump in 3 years and will get an aem or walbro by next week. (08 lgt) Sent from my SM-G935V using Tapatalk Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
perfweld Posted October 11, 2017 Share Posted October 11, 2017 All went well with the car, the AEM pump is working great. Today it was tuned and made 293 hp and 330 TQ. It was really hard to tell the tuner to not give me an overly aggressive tune, I have to keep telling myself its not my race car and I don't wanna break it. So the AEM pump is a go FYI, works great. Link to comment Share on other sites More sharing options...
Sarang Posted October 20, 2018 Share Posted October 20, 2018 Just got done installing an AEM 50-1215 fuel pump. You'll notice that's not the same part number as above. I ordered the wrong one, but decided to see if it would work. It does, I only had to remove two plastic clips so that it would clear. Once I did that it's the same length as OEM so it snapped right in. Drove to the gas station and filled up, everything seems to work perfectly. I can kind of hear the pump on startup. If that gets to bother me, I may stuff a foam pad down between the tank and the panel. Link to comment Share on other sites More sharing options...
