MasAyinde Posted August 16, 2016 Share Posted August 16, 2016 So I just tried flashing a new ROM to my ECU. When it was almost done flashing, it seems like the connection dropped out and I got this error: [17:36:43.032] J2534 error [ERR_TIMEOUT]. I had gotten this error before but it didn't even allow me to start to flash. When the error popped up, I looked on my dash and my dash was saying "Run mode change system check" and cruise was flashing. I immediately suspected the worst, bricked ECU. My question is, what are the symptoms of a bricked ECU? My laptop can connect to and read the ECU since I can still pull logs (battery voltage, which is 11.86, coolant temp) and ECUFlash will still connect to the ECU. I suspected a bad battery so I tried jumping it for a bit, and after about 3 minutes of having another car connected, my Subaru cranked twice and then died again, still with the Run mode... error. Would a bricked ECU EVER crank like that? I want to believe that it's just a shit battery, since it's 4 years old, has completely drained twice and was sitting for 6 months at one point disconnected. I'm only bringing up this post since I don't have a way of installing a new battery before Friday, but I do have time to remove my ECU and overnight it somewhere to be unbricked. Link to comment Share on other sites More sharing options...
MasAyinde Posted August 16, 2016 Author Share Posted August 16, 2016 My battery theory comes from this post on this site where the OP hasthe same error message: I just got a call from the dealershiip. Verdict: Bad Battery. And even better news they did not give me a hard time about the HID's and they are not billing me for ANYTHING, rental, labor nothing. They didnt have to do that. P.S. "Built to last, DuraLast!" is a crock of shit... Duralast Gold 800 CA & 640 CCA - Now it tests 64 CA : I also have a Duralast battery... Link to comment Share on other sites More sharing options...
whitrzac Posted August 16, 2016 Share Posted August 16, 2016 Disconnect the battery and hook the car directly to the other car's battery. See if it starts. Car batteries can short internally. Link to comment Share on other sites More sharing options...
MasAyinde Posted August 18, 2016 Author Share Posted August 18, 2016 ECU not bricked. Tried to flash again and it worked. Link to comment Share on other sites More sharing options...
