funnyman06 Posted November 4, 2017 Share Posted November 4, 2017 how is the rear ride height? Should I move the adjustable spacer up the the 2nd from the top? Give it a little more pre-load? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 4, 2017 Share Posted November 4, 2017 Well, my car is still on jackstands I bought this stuff almost a year ago and have yet to enjoy the ride . Hopefully, I'll put everything back on the car within the next two weeks or so. But note that I will be using the rallitek overload rear springs and my rear shocks have also been revalved. Link to comment Share on other sites More sharing options...
funnyman06 Posted November 5, 2017 Share Posted November 5, 2017 Install went well, the rear strut install fought me tooth and nail but I finally came out on top. A little map gas and a big impact go a long way. Car overall rides exactly how it should have from the factory. I'm very happy with it, however I also found that at least 1 ball joint is bad so Ill have to replace those and then get it aligned. If you are on the fence, i understand its some serious $$$, however the car is finally nice to drive. Install took me the better part of 4.5 hours, alot of that was me fighting with the rear end. I assembled one and then realized i forgot the boot. Then I got them both in the car and realized I didn't use the rubber spring seat. O well, its done and I look forward to driving it more. Link to comment Share on other sites More sharing options...
Dispatch20 Posted August 30, 2018 Author Share Posted August 30, 2018 There are a couple sets of BTS5056 up on eBay now. Surprised they weren't quickly bought. Link to comment Share on other sites More sharing options...
M. Schneider Posted September 1, 2018 Share Posted September 1, 2018 funnyman06 - Glad you like the Bilstein BTS Kit outcome. Having been ground zero on this enhancement I must say the newfound BTS suspension continues to suit the Outback XT well; current mileage is 100,000 mi. plus,,, with the initial BTS install at 50,000 mi. IIRC. Edit Car overall rides exactly how it should have from the factory. I'm very happy with it, Edit Cheers, Mike |`94 E-Class Coupe |`98 Carrera 993 C2S |`14 Cayman S |`20 Outback Touring XT | All Debadged | Link to comment Share on other sites More sharing options...
dukeneverwinter Posted February 21, 2019 Share Posted February 21, 2019 Have a set of used 5056 on the way. I was going to have the rear revalved to Rallitek overload sprongs because bstein is local to me. Are there options for stiffer front springs? Would these work? https://www.rallitek.com/oe-height-springs/9409-rallitek-0-front-springs-outback-2005-2009.html?gclid=CjwKCAiAkrTjBRAoEiwAXpf9CUDqgLA0Unbrkjb1EmhqmxzkdQ8h0AtwpVr780g9F4Q44sDND_n32hoCSA0QAvD_BwE Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 21, 2019 Share Posted February 21, 2019 I don't think you really need stiffer front springs. I have the exact set up that you are planning to have. Pretty happy with it. I did add a 1+1/4" lift kit though. Link to comment Share on other sites More sharing options...
