Water stains on headliner?
I bought my 2016 Legacy 3.6R about 6 months ago and have had no problems other than a flat tire, but recently while washing the insides of the windows I noticed water stains on the headliner on both rear window pillars. Has anyone seen this pattern before? Where is the water leaking in?77
Pete
Edited by Retserof
Thanks. I will have the dealer look at it soon, but removal of the headliner is not a simple procedure, so I thought it would be helpful first to tap the collective wisdom of this forum.
I figured that the sunroof rear drain hoses would both have to be disconnected from the drain pan or have some sort of holes in them, which seem unlikely.
A leak at the roof antenna is another possibility, but I would expect a central water stain from that.
Based on the location, leaks around the rear window's anchor points seemed most likely to me.
Because there are several possibilities, I am hoping someone else would recognize this stain pattern and actually know the location of the leak(s).
Pete
Pete
Seems like random water leaks are the achilles heel of these cars. I would defintely have the pull the headliner and replace it. I think you're correct that a drain is plugged. Most of the leaks I'm familiar with are in the front floor boards. I noticed my sunroof drips small amounts of water in rain and when washing, but there is a catch basin for that reason. Seems like they designed them to leak with the expectation to drain the water out. Weird.
I'm with Andrew, my money would be on the sunroof drain tubes.
*To elaborate on my thoughts. I don't think the tubes would have to come completely disconnected. I think there could be a partial disconnect, or a loose connection, and water is running down the side of the tubes. Something along those lines is possible in my opinion. Or simply water bypassing the drain tubes, and running down the sides of the tubes.
Edited by apexi
I bought the car new in early February. I have an appointment with the dealer on Monday morning. We'll find out then.
Tuesday Update -- after the technician looked at the stains, the dealership decided to order a new headliner, sunroof track, seals, etc., before pulling the interior apart to investigate the source of the leak. I'll let you know what happens next.
Edited by Retserof
  • 3 weeks later...
UPDATE: The dealer discovered that the water stains on my headliner were from a leaky sunroof gasket. The leak was worst at the right rear corner. The sunroof drip tray's 4 drain hoses were all properly connected and were not blocked by debris. Apparently, the volume of rainwater getting past the gasket was so great it overwhelmed or simply sprayed past the sunroof's drip tray and ended up on top of the headliner, where it ran back toward the rear window and the C pillars. From there, it dripped down into the rear seat belts/retractors, staining the seatbelts. There may also have been a small rain leak from the SIRIUS roof antenna.
Even after the parts arrived, the repairs took several days to complete. The dealer replaced the sunroof glass with its integral gasket, the headliner, the roof antenna, and the rear seat belts. They tie-wrapped the drain hose connections as a precaution and adjusted the closed position of the new sunroof glass to be a little higher in the roof opening so water won't pool on it so readily. The new glass seems to have a slightly thicker or puffier gasket than the original one, so that should help too. All parts and labor were covered under warranty.
The dealer's technician did a careful and thorough job and is confident that the problem has been corrected. He told me that my Legacy is the second new one he's seen with a leak like this. We haven't had any heavy rain since, so I'll have to wait and see if all is well.
Believe me, I would not have a sunroof either if Subaru gave me the choice of deleting it. I am severely allergic to wasp stings, and I too often have a problem with the ceiling height in cars. This Legacy is the first time I've owned a car with a sunroof.
  • 3 years later...
I have headliner stains similar to the original post but I have no sunroof in my 17 Legacy. Had it to the dealership 4 times and they finally replaced the shark fin antenna on the roof and "cleaned" the headliner. All under warranty, but very annoying to have to go back 4 times.
If you need to still remove any stains, I would highly recommend this product:
https://www.meguiars.com/automotive/products/meguiars-carpet-upholstery-cleaner-car-upholstery-cleaner-fabric-cleaner
I once had a can of grape pop explode in my car and it stained EVERYTHING and EVERYWHERE purple. Fortunately, with an application of this on the headliner and seats, everything came out and looks brand new again.
Thanks! As of now, it's still a warranty issue that the dealer needs to make right. Looks like I'm going back in for the fifth time!
