Iandierks Posted August 11, 2016 Share Posted August 11, 2016 Hey guys so I just recently purchased an 06 obxt and I'm just in the process still of combing through the car and working out the kinks. About 10k miles ago the turbo was supposedly replaced with a larger unit. I ended up having to take the car to the local dealership to have an unrelated issue sorted out and they told me that they had found some metal shavings in some oil outlet tube (or something to that affect) in thinking maybe that was from the old until that was replaced? Any way I can check the current unit to make sure it's still operating correctly, and also the previous owner knew they replaced the turbo with a larger one but how can I figure out which turbo it actually is? Thanks! Link to comment Share on other sites More sharing options...
JF1GG29 Posted August 11, 2016 Share Posted August 11, 2016 The turbo will generally have the model number stamped or printed on the compressor side. What did you have the dealership do? Why would they be removing the turbo? Link to comment Share on other sites More sharing options...
Iandierks Posted August 11, 2016 Author Share Posted August 11, 2016 They didn't do anything with the turbo, they replaced the throttle body because the TPS was malfunctioning Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2016 Share Posted August 13, 2016 See if you can get a picture of the numbers on the compressor inlet. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
wtdash Posted August 15, 2016 Share Posted August 15, 2016 ... they had found some metal shavings in some oil outlet tube (or something to that affect) in thinking maybe that was from the old until that was replaced? Not sure why this isn't a red flag......as I understand it, these end up in the engine and cause 'issues'. The old VF40 (?) turbos were known to explode and take the engine down w/it. I'd look online/here to see the best way to 'clean out' the engine oil, including removing those screens in the lines to the heads and turbo. I'd get an oil analysis (Blackstone, for example) and verify the internal condition. If it has 10K miles since the turbo replacment maybe that's a good sign. GL, TD Link to comment Share on other sites More sharing options...
