jsmythe Posted August 9, 2016 Share Posted August 9, 2016 I was trying to adjust the headlight aim and discovered the headlamp assembly loose, swiveling up and down freely. The dealer said the bottom tab is broken and so is the bumper bracket to which it's attached. I have found some diagrams and pictures of bumper disassembly but cannot find the bracket. Anyone know which one it is? I'm trying to source one on ebay... Link to comment Share on other sites More sharing options...
RJ255 Posted August 13, 2016 Share Posted August 13, 2016 I doubt the bracket is broken, it's made of metal and pretty sturdy, unless you had a front end collison and broke it that way. If anything is broken, it's likely the tab that attaches the headlight to the bracket, it's pretty flimsy. But if you need the part number, for the left bracket: 57707AG22A and the right bracket: 57707AG21A Link to comment Share on other sites More sharing options...
jsmythe Posted August 14, 2016 Author Share Posted August 14, 2016 I doubt the bracket is broken, it's made of metal and pretty sturdy, unless you had a front end collison and broke it that way. If anything is broken, it's likely the tab that attaches the headlight to the bracket, it's pretty flimsy. But if you need the part number, for the left bracket: 57707AG22A and the right bracket: 57707AG21A Ahhh,thank you. The dealer wrote it up that the tab was broken and the bracket would have to be replaced - at an estimated cost of $650! Also said that if it wasn't bothering me I could leave it alone. Anyway, I discovered that the aiming screw was still operable and was able to aim it. Good to have the info, thanks! Link to comment Share on other sites More sharing options...
RJ255 Posted August 15, 2016 Share Posted August 15, 2016 No problem. Yeah 650 is a bit much for something that probably isn't even broken. Link to comment Share on other sites More sharing options...
