Dyllanbmx Posted August 8, 2016 Share Posted August 8, 2016 Hey Guys, every now and then when taking off from 1st, ill get a popping noise or a thud kinda noise around when the clutch bites. just wondering if any one has had the same problem or has an idea what it could be. im in need of a new clutch as it is so i will be getting it all looked at in the near future, just wanted to know if it was something i will need to budget for on top. But anyways, i want to hear people opinions and experiences with aftermarket clutches and OEM clutches. At this point in time my cars just for street use, but id like to do some track days later on down the track, so i want something nice to drive, but something that will hold up under track abuse. Thanks in advance:) Link to comment Share on other sites More sharing options...
Max Capacity Posted August 8, 2016 Share Posted August 8, 2016 http://www.tuningalliance.com/home.html Contact Brian at TA he can help you out. It's a new site that is still being constructed, but they can get you anything you might need. I've been dealing with them for over 6 years now. Other trusted members are "underdog" you can PM him. or Rey or Mike at http://www.AZPinstalls.com, they are in NJ. Tell us where your from ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dbrunone Posted November 7, 2016 Share Posted November 7, 2016 I actually started getting the same thing about a month ago. Just like you describe. However mine is an 07 Spec.B with 149k with original clutch/etc so I figure it's about time for something to go... Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2016 Share Posted November 9, 2016 A few month's back Brian at TA was happy with Southbend Clutches as seem to be a lot of people. I still like my Spec 2+ Clutch. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
