iNfEk Posted August 7, 2016 Share Posted August 7, 2016 So I think this is probably the stupidest design. How can I remove this upper bolt/but since it seems like the nut is stripped and over tightened. I used extended spline drive ratcheting wrenches and still cannot budge either side. http://uploads.tapatalk-cdn.com/20160807/70c546a3936ca1bccf1a59c6101e9dd6.jpg Any productive help is greatly appreciated. Can't install white line lateral links without removing these and cannot install just 3 of the 4 since this is the camber adjustment side. Link to comment Share on other sites More sharing options...
rapture Posted August 7, 2016 Share Posted August 7, 2016 Lol u prob gott drop the subframe Aand then might need heat or cutting wheel New bolts Whatever u do Dont just start throwing flame at it while its on Cause ur gas tank is rite above And try not to damage those flimsy ass pieces on each side cause that would truly suck Link to comment Share on other sites More sharing options...
iNfEk Posted August 7, 2016 Author Share Posted August 7, 2016 Lol u prob gott drop the subframe Aand then might need heat or cutting wheel New bolts Whatever u do Dont just start throwing flame at it while its on Cause ur gas tank is rite above And try not to damage those flimsy ass pieces on each side cause that would truly suck Yeah that's what I thought would need to happen which seems ridiculous. It's in a fucked up area too. Should've made at least and access hole or something. Link to comment Share on other sites More sharing options...
rapture Posted August 8, 2016 Share Posted August 8, 2016 I just went thru the same shit I finally got to replacing my rear trailing arms with these sweet spec b ones w delrin inserts for the larger front bushing And while i was doing that i had the other lateral links to replace/upgrade ( megan) Had the same issue Bolt was stripped/siezed , camber bolt didnt move Had to drop the subframe Honestly when attacking shit like this i prefer to have any bolts oem new on hand You mine as well imo The entire set of bolts for everything cost like 50-60$ And you always have the older ones for back up Id also grab a few cans of pb Link to comment Share on other sites More sharing options...
iNfEk Posted April 15, 2017 Author Share Posted April 15, 2017 Lol. I probably will buy a but splitter. To hopefully save me from dropping the subframe. Basically breaks the but off while saving the bolt and threads. Link to comment Share on other sites More sharing options...
