vhtran Posted August 6, 2016 Share Posted August 6, 2016 Hello, I am sorry for creating another post instead of the search. However, it is easier to keep track the responses and not jacking up other's posts. Anyhow, I have just done the retro on the headlights and obvious the light is much brighter than the OEM or the LED+OEM projectors. However, I am not so happy with the cut off of the beams. Up close to the wall, the beams do have the sharp cut off, but once I move further away from the wall, the beams change and the cut off replaces with 2 arcs (right on top of the hot spots). Could I trouble someone up here direct me to the correct adjustment for the lights? Link to comment Share on other sites More sharing options...
utc_pyro Posted August 6, 2016 Share Posted August 6, 2016 Hate to say this, but to properly fix that you'll need to open them up and mess with the lens spacing. It also looks like the projectors are rotated slightly, but that may just be bowling. Link to comment Share on other sites More sharing options...
vhtran Posted August 21, 2016 Author Share Posted August 21, 2016 I was able to open them up again and fixed this issue. I had the mounting bracket between the projectors and their shields instead of between shields and the housings. Everything looks now. I hope someone can use this as a reference for their issues. Link to comment Share on other sites More sharing options...
fedaykin Posted August 24, 2016 Share Posted August 24, 2016 Hehe easy enough mistake to make. Got some "after" photos? Link to comment Share on other sites More sharing options...
