Single DIN
Stevh0
My cubby had been butchered by the previous owner who fitted a parrot and a gps in there. From far it looked alright, but upclose it made me gag.
Anyhow, I ripped all of it out and Ill remove the rear cubby too. unfortunaly the owner ripped the lid off, otherwise I might have kept it oem and gone with an AVO kit.
So, Im going to mount a single din in there and "borrow" power from the oringal headunit.
I plan on either splicing the power / ignition cable to my single din.
I'm also going to be cutting my OEM speakers off from the harness and relocated their wires to the amplifier, which I'm not sure where I'm going to mount. Just makes it easier than running new wires to the doors and the bonus is I can always return to stock down the line.
So my question:
Anybody see anything wrong with splicing the OEM wires for power - or should I just cut the power completely from the OEM unit? (I won't be using it ) Unless of course, it interferes with the climate control below it.
Man this sounds so quick and painless... I bet its going to take up my whole Saturday.
  • 2 weeks later...
Yeah, that was initially an option. However they were all import and would take a while to get here.
So I decided to give it a go.
I removed the radio and was shocked to see what they had done when they installed the parrot.
http://uploads.tapatalk-cdn.com/20160809/24bba4ade6d2b473004db696af321d4d.jpg
http://uploads.tapatalk-cdn.com/20160809/ce5a9c636a1cdffc84089c1e26020c21.jpg
The actual rewiring of the unit wasn't too bad. I got a good speaker wiring layout online and I just really connected the wires and disconnecting the parrot. Luckily the parrots mic fits into the kenwood so I left that behind.
http://uploads.tapatalk-cdn.com/20160809/1b72e5248c2e97981549f3a3d77fb272.jpg
I also cleared out most of the dust and junk behind the dash. The previous owners really did use the car on dirt.
I just need to either make a mold or something that fills the small gap at the top or find a way to neaten it up. I'm stoked at the fact that I can play USB now, but the overall neatness of the dash is still getting to me.
http://uploads.tapatalk-cdn.com/20160809/b6f3875ca9d50a461cd3b6cbf6899c76.jpg
I'm getting ready to do this and want to use the F150 metra kit that someone posted before. There's a small slot that fills up the extra space except it's at the bottom. I found the exact part before but now I can't anymore. Does anyone have that link?
Although I'm curious how the OP got to that final fit from this shot with the sides of the cubby and plastic lattice showing. You need to cut / angle the bottom a little bit to cover that offending portion.
http://i105.photobucket.com/albums/m204/craigh95630/IMG_0659.jpg
